jpbb
modprobe not working properly on 2017.4
I am currently working on the zcu102 board. I generated a custom Linux module with "petalinux-create -t modules --names fpga --enable". The module fpga.ko is built and placed into /lib/module/4.9.0-xilinx-v20117.4/extra
It is started at start-up when booting the kernel. I guess it runs insmod. It is possible to unload the module via rmmod..... But when trying to "modprobe" the module, it returns that the module cannot be found in modules.dep.  The module IS in modules.dep and has no depedency (extra/fpga.ko:     )
I tried different things:
  1. Regenerate modules.dep (depmod -a)     No SUCCESS
  2. move fpga.ko into .../kernel/drivers/misc and regenerate   No SUCCESS
  3. force modprobe via -f , option not supported.
Could you check  that this functionality is working for you. Is there any problem with 2017.4?
Thanks in advance for your help!
JP
jpbb
well.... I checked again and it works as insmod (you have to type "modprobe fpga"
regards JP
trigger
Hi @jpbb,
Why you don't use insmod cmd to load like at boot?
Cheers,
Trigger
jpbb
I unsderstood that "insmod" is just loading the module. Modprobe is loading +initializing the module.
Insmod does not run the probe function in the driver... and it is what I wanted to do
JP
jpbb
regards JP
