lucien-wang
mount: mounting /dev/mmcblk0p1 on mnt/ failed: Invalid argument
below is my emmc schematic and vivado(2019.1) config
the emmc chip is connected to sd0
then i export hdf file with bitstream,use petalinux config and build the mirror for qspi boot,and boot successfully;after that ,i used fdisk cmd partiation the emmc disk and format partation ,it is also successful,below is formated disk
root@plnx-psbase:~# fdisk -lu
Disk /dev/mmcblk0: 7264 MB, 7616856064 bytes, 14876672 sectors 232448 cylinders, 4 heads, 16 sectors/track Units: sectors of 1 * 512 = 512 bytes
Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type /dev/mmcblk0p1 0,1,1 1023,3,16 16 14876671 14876656 7263M 83 Linux
but when i mount p1 disk to a new floder ,it is fail
root@plnx-psbase:~# mkdir mnt
root@plnx-psbase:~# mount /dev/mmcblk0p1 mnt/
what casue the problem?anyone can help me !thank you
stephenm
Is it already mounted? Petalinux will auto-mount
lucien-wang
no auto-mount! attached file is my uart(shell) exported log,which included boot log and my cmd excuted log
i used df cmd for checking emmc disk mounted file ,but nothing can find
root@plnx-psbase:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 494376 4 494372 0% /dev
tmpfs 515176 76 515100 0% /run
tmpfs 515176 44 515132 0% /var/volatile
another question
the ug585  show below:
Is it because the SD controller does not support higher mmc standard ?my emmc  is  MTFC8GLVEA-1MWT
stephenm
Does it fail to probe? Can you do a dmesg on this controller?
lucien-wang
Thank for replying
I am sorry for not knowing how to “do a dmesg” for this controller.
Can you give me operate flow or user manual.
watari
Hi @lucien-wang
Would you execute the following command on the terminal of your device ?
dmesg
BTW, it's helpful for us, if you share whole boot log message instead of "do a dmesg".
Best regards,
