ariels1
mount mtdblock Error when booting from flash witj linux 3.8
hi,
we use zc702.
on flash we have:
zynq>uname -mrs
Linux 3.8.0-xilinx-dirty armv7l
we set the flash mtd4  to jffs2.
doing:
zynq> mount -t jffs2 /dev/mtdblock4 testmnt
gives those ERRORs:
jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000000f8: 0x19d4 instead
jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000000fc: 0x002e instead
jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000100: 0x9ed4 instead
jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000104: 0x0002 instead
ETC...
doing the same when boot from SD with
zynq>uname -mrs
Linux 3.5.0-14.3-build2-25242-gd274001 armv7l
works fine.
if someone can help ,
we'll be gratefull.
thanks in advance
best regards
ari.
p.s
the same device tree is used in both SD and flash.
partition@qspi-fsbl-uboot {
label = "qspi-fsbl-uboot-bitstream";
reg = <0x0 0x600000>;
partition@qspi-linux {
label = "qspi-linux";
reg = <0x600000 0x400000>;
partition@qspi-device-tree {
label = "qspi-device-tree";
reg = <0xA00000 0x20000>;
partition@qspi-ramdisk {
label = "qspi-ramdisk";
reg = <0xA20000 0x2E0000>;
partition@qspi-scratch {
label = "qspi-scratch";
reg = <0xD00000 0x300000>;
milosoftware
MTD with the qspi flash driver was broken for a while in the 3.8 version of the Xilinx kernel, the current version (3.9) in the Xilinx git works fine once more. I'd suggest upgrading to the current master and try again. The newer versions will also let you use more than 16MB if you have it (e.g. the zedboard).
ariels1
using
Linux 3.0.0-14.1-build3 armv7l
on the flash works fine too.
so something not working well with  3.8 ..
any suggestions?
thanks.
milosoftware
ariels1
thanks..
we will..
is there a place where i can see all those bugs ?
best regards
ari
