mount spi flash error
I use zynq ps spi1 to connect a spi flash called n25q128a11.
My devicetree is as follows.
spi@e0007000 {
			compatible = "cdns,spi-r1p6";
			reg = <0xe0007000 0x1000>;
			status = "okay";
			interrupt-parent = <0x4>;
			interrupts = <0x0 0x31 0x4>;
			clocks = <0x1 0x1a 0x1 0x23>;
			clock-names = "ref_clk", "pclk";
			#address-cells = <0x1>;
			#size-cells = <0x0>;
			is-decoded-cs = <0x0>;
			num-cs = <0x1>;
			flash@0 {
				compatible = "n25q128a11";
				reg = <0x0>;
				spi-max-frequency = <0xf4240>;
				spi-tx-bus-width = <0x1>;
				spi-rx-bus-width = <0x1>;
				#size-cells = <0x1>;
				partition@test {
					label = "spi-flash";
					reg = <0x0 0x100000>;
I also enable mtd settings in kernel config.
however, when I booting the linux it goes wrong.
Could someone give me some help?
Thanks very much.
The attachment is the devicetree.
Re: mount spi flash error
Hi @felven,
Can you please keep the compatible name as mentioned below in your spi device tree node?
flash@0 {
compatible = "n25q512a", "micron,m25p80";
Flash driver will be invoked by kernel once compatible string "m25p80" matches.
Also check for  alias name of spi@e0007000 whether it is set for alias "spi0" in your device tree or not.
Kranthi
Best Regards
Kranthi
