move bare metal (standalone) app to linux
I've finished developing a standalone application and now I'm trying to move it to Linux OS, I'm using Petalinux and have no problem with Linux, but I don't know how to build the binary image in Xilinx SDK, I tried to create a new application in SDK (using linux os platform) but when I include any header file (like #include "xuartps_hw.h") the SDK give me an error.
"error: /Projects/PetaLinux/Nav/build/linux/rootfs/stage/lib/libgcc_s.so.1 uses VFP register arguments, test1.elf"
also
"Unresolved inclusion: "xuartps_hw.h""
I'm using Zedboard and I tried both SDK 2015 and 2016.
my project involved (SPI , IIC , UART and GPIO) peripherals.
Is it possible to make the standalone application works in Linux OS?  I mean all the required source files could be built in Linux? or I have to write a new program not in C?
Thanks in advanced.
It looks like you are trying to mix standalone BSP code/driver (i.e. xparameters.h, xuartps etc) and Linux. These two are not compatible. If you intend to use Linux, you need to use the Linux drivers and frameworks to interface with the peripherals.
Just to make my question more simple,
can I create a Linux application using the C examples which provided in the SDK, like, example to use IIC in polled mode?
thanks.
@akkadhim1
Follow the instructions in the link
http://www.xilinx.com/video/hardware/how-to-create-linux-applications.html
http://www.wiki.xilinx.com/Create+Linux+Application
Achutha
Thanks Achutha.
I tried to build the videos example and it works fine, but when I start to add any peripheral, I got an error about the header files.
I'm still not sure if I can use the mentioned method (in the video) to build a Linux application which includes (spi, Uart or IIC peripherals) because I read some posts about that like this one:
https://forums.xilinx.com/t5/Embedded-Linux/Building-applications-for-Petalinux/m-p/682098/highlight/true#M15375
also in this post they faced same issue
https://fohttps://forums.xilinx.com/t5/Embedded-Linux/App-in-Petalinux-ERROR-found-xparameters-h/m-p/565384/highlight/true#M12014rums.xilinx.com/t5/Embedded-Linux/App-in-Petalinux-ERROR-found-xparameters-h/m-p/565384/highlight/true#M12014
regards.
Based on your reply (Linux drivers and frameworks), could you please give me more details on how can I do this step by step, because I have exactly the same issue as aforementioned?
