Visitor jh1130.lee
multiple jtag for petalinux-boot
I am using petalinux 2017.4 and 2018.2 and ultrascale board.
I successed to upload bit files into board using jtag.
But I have one additional vertex 7 board.
Also I have one more xillix jtag cable.
So I hope to use multiple jtag at one PC.
In the petalinux-boot help, there are options related jtag control.
JTAG available options:
--load-addr <LOADADDR> address to load the image
--regdata <REGDATA> register data
--before-connect <CMD> extra command to run before XSCD connect
command.can be used multiple times
--after-connect <CMD> extra commands to run after XSDB connect
E.g. --after-connect "jtag targets 1"
--xsdb-conn <CONNECT_CMD> customised XSDB connect command
--hw_server-url <URL> specify the URL of the hw_server to connect to.
This argument is optional and defaults to blank (local).
An example URL is: "TCP:localhost:3121"
--tcl TCL_OUTPUT dump XSDB commands to the specified file
--targetcpu <TARGET_CPU> specify target CPUID (0 to N-1)
--fpga Programs the hardware with the specified
bitstream. If not specified, it will use
the bitstream found in images/linux/.
--bitstream <BITSTREAM> Programs the hardware with the specified
bitstream.
I don't know how to override XSDB options at below page into petalinux option.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_3/SDK_Doc/reference/sdk_u_xsd_xsdb_jtag.htm
I used like below, and it was fail.
Bus 001 Device 005: ID 03fd:0008 Xilinx, Inc. Platform Cable USB II
Bus 006 Device 004: ID 03fd:0008 Xilinx, Inc. Platform Cable USB II
petalinux-boot --jtag --kernel --bitstream bitfile.bit --before connect "jtag targets 1"
Re: multiple jtag for petalinux-boot
Hi @jh1130.lee
In order to connect to more than one target from to the same host, you could run different hw_server lisening to different port for each target. Then you just need to link each hw_server to a specific target. To do so, you can refer to the following Answer Record.
After doing so, you can connect to any of these targets using the "petalinux-boot" option "--hw_server-url", e.g. :
    petalinux-boot --jtag --prebuilt 3 --hw_server-url <hostname:3121>
More details about this option, could be found on this document.
Best regards,
Abdallah
