netatalk to rootfs using Petalinux
I am using Petalinux 2018.3 to build my kernel and rootfs for a Zynq Ultrascale+ design.  What is the best way to add netatalk to the rootfs?  I need to support the protocol but can't easily figure a way to do it.  Modify the busybox package?  Some other approach?
Re: netatalk to rootfs using Petalinux
Build the executable from sources and then add it to petalinux as a prebuilt application
Refer to Page 66 on adding prebuilt applications
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1144-petalinux-tools-reference-guide.pdf
Best Regards
Shabbir
I thought about that, but it requires a bunch of libraries that are available in the petalinux distribution.
