betanken
network settings of ubuntu rootfs on petalinux
Hi all
I'm using ubuntu rootfs on petalinux now. I have tried to use $apt-get update, but its failed.
Here the errors:
All packages are up to date.
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-updates/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/xenial-security/InRelease  Temporary failure resolving 'ports.ubuntu.com'
W: Some index files failed to download. They have been ignored, or old ones used instead
Maybe I should use other sources instead http://ports.ubuntu.com/ubuntu-ports/ in etc/apt/sources.list?
Thanks a lot for help
Holzmann
deville
Hi Betanken,
If your company has a DNS server running, chances are great you are behind a firewall.
Look at this link
https://help.ubuntu.com/community/AptGet/Howto
and go to the section: Setting up apt-get to use a proxy
trigger
Voyager
Voyager
betanken
Hi @trigger
Thanks for reply.
I have checked it, it doesn't work for me....
trigger
Voyager
Voyager
Does adding nameserver 8.8.8.8 (Google's DNS server) to a new line on /etc/resolv.conf have any effect?
[EDIT]: probably need also:
sudo service resolvconf restart
Cheers,
Trigger
betanken
Our company has DNS server, and I don't think I need to add google DNS server in it....
On /etc/resolv.conf I can see nameserver of our company
trigger
Voyager
Voyager
@betanken are you able to ping an external server ?
Because of in your log you have only warnings no errors ...
deville
Hi Betanken,
Look at this link
deville
You can do some additional test to see if your DNS server is working
$ nslookup ports.ubuntu.com
it should give you 91.189.88.150 as an address
next, try to ping to the server
$ ping 91.189.88.150
or
$ ping ports.ubuntu.com
If you are able to get a return message, you should look at your proxy settings. ( or ask your administrator ) otherwise it is likely your network ( hard- or software ) is malfunctioning.
betanken
Hallo @deville
Yes you are right. I checked the internal data-sheet of network settings and resolved the issue. Thanks
betanken
@trigger
I solved the problem, thanks.
