04-14-2018 02:03 AM
Hey evryone !
i am using zybo 7010 in ubunto 16.04
I generate a BOOT.BIN and an image.ub, I put the two files in the SD card but it does not boot!
in vivado i activate UART0 and UART1.
jumper is good.
I enclose the two files system-user.dtsi and system-conf.dtsi.
my serial terminal is /dev/ttyUSB1.
please helpe !
04-15-2018 08:04 PM
Hi @mohamd17
Would you try qemu to make sure your boot sequence ?
It's easy way to find the route cause, even if you can not use serial interface.
http://www.wiki.xilinx.com/QEMU+-+Zynq-7000
Best regards,
04-16-2018 08:11 AM
Hi @mohamd17,
Are you sure that serials are enabled ?
aliases { serial0 = &uart0; }; &uart0 { device_type = "serial"; port-number = <0>; status = "okay"; };
Cheers,
Trigger
