meds7
no kernel sources in SDK with yocto flow
I use the yocto flow to generate kernel and rootfs, all based on the Xilinx rel-v2020.2 yocto recipes.
Then I want to include the kernel sources in my SDK which I can generate with :
$ bitbake petalinux-image-minimal -c populate_sdk
In my conf file I added :
TOOLCHAIN_TARGET_TASK_append = " kernel-devsrc"
After creation of the SDK i can see the complete directory structure of the kernel sources in my sysroots/aarch64-xilinx-linux/usr/src/kernel directory, but only the Kconfig and Makefile files are present. Therefore no actual kernel sources seem to be deployed in my SDK.
Any ideas?
Tags (3)
hokim
kernel-devsrc is used for external(out-of-tree) module builds
So it doesn't include all source files
https://github.com/Xilinx/poky/blob/rel-v2020.2/meta/recipes-kernel/linux/kernel-devsrc.bb#L60-L65
meds7
Hi, is this something which has changed in this yocto recipe? In the past it gave me all driver sources...
