Participant coreyhahn
noob Question: How to insert a boot script between two boot items in petalinux
So I have a boot script, it runs at S99 in rc5.d.  But that is too late.
The script initializes a clock generator with i2c commands and I need the clock generator up before usb3 is initialized.
How do I first figure out where i2c and usb3 are initialized, and secondly insert my i2c/clockgen script inbetween them.
Hunting through init.d scripts I cannot find anything resembling "init_i2c" and "init_usb3".   Where do i start?  Is this in the kernel?
Thanks in advance.
Corey
Re: noob Question: How to insert a boot script between two boot items in petalinux
Hi @coreyhahn
Yes you can run scripts in u-boot using source commands. Refer http://www.denx.de/wiki/view/DULG/UBootScripts
Sandeep
Related to this, is it possible to run a script in uboot?
Hi @coreyhahn
Sandeep
Excellent!  Is there a way to then have the script run at boot every time before the Linux kernel image starts instead of downloaded and run manually?
platform-auto.h, used in U-BOOT has a #define CONFIG_PREBOOT that contains a small script run just before boot of the kernel.  I2C is up and running in UBOOT so I just stuck my config script inside this #define by modifying platform-top.h.  this file looks to be also used in UBOOT.
#undef CONFIG_PREBOOT
#define CONFIG_PREBOOT "My new script; Default Preboot script stuff:"
