one question
Hi friends, the ramdisk file that is in wikidot is good for the ml310 board?
I am not sure, but I think that it is okay for any system.  Make sure that you compile your kernel with the ramdisk.image.gz file in the arch/powerpc/boot/ directory.  Make sure that you configure your kernel properly using make ARCH=powerpc menuconfig and save the file in the arch/powerpc/configs/44x/ directory.  Make sure that your correct dts file is in arch/powerpc/boot/dts/ directory and that it is named xxxx.dts where your _defconfig file contains:
CONFIG_EXTRA_TARGETS="simpleImage.xxxx simpleImage.initrd.xxxx"
for example:
virtex440-ml310.dts
CONFIG_EXTRA_TARGETS="simpleImage.virtex440-ml310 simpleImage.initrd.virtex440-ml310"
Use make ARCH=powerpc 44x/your_config_file_defconfig to load you save configuration.
Make sure to run make ARCH=powerpc zImage and then use the simpleImage.initrd.xxxx image as the simpleImage.xxxx will not contain the ramdisk.
You may have tried all of that already, but just is case I wrote it here.  Good luck.
Message Edited by ltovey on 04-13-2010 04:40 PM
