Visitor vale_marche
peek and poke don't work with Petalinux
I am using a ZC702 board to carry out my tests with Petalinux.
The other day, while deploying the original base TRD, rdf0286-zc702-zvik-base-trd-2015-4, on the board,
I wanted to use peek and poke commands to access GPIOs, but they didn't work - the shell was returning "command not found" messages. (I tried it for the first time with this design.)
However, shortly before that, I successfully used peek and poke with another Petalinux design, viz. 2015.4-zc702.
Does anyone knows what might be missing in the former TRD to support peek/poke, and how Petalinux shall be configured to get them installed and working?
Regards, Valery
Visitor vale_marche
Re: peek and poke don't work with Petalinux
Hi Shabbir,
thank you for the quick tip - that's been it, of course!
(Actually, I had briefly sought for something like that in the petalinux config, but just overlooked).
Kind regard,
Valery
Check in your petalinux-config -c rootfs ---> apps ---> peekpoke, whether these packages are enabled? If not enable and rebuild the images and boot.
Best Regards
Shabbir
Visitor vale_marche
Hi Shabbir,
Kind regard,
Valery
