petainux-boot-zynq
i was trying to run the petalinux build for opencv libraries enable and want to run application on the zybpo board for that i was created and change the config setttings(opencv enable)but got the below error when boot the images on board.
 anyone help me out
K sharmila
Re: petainux-boot-zynq
HI @sharmilakotra123
Can you check  If kernel or rootfs size increases and is greater than 128 MB, you need to do the following & try once.
1. Mention the Bootm length in platform-top.h
#define CONFIG_SYS_BOOTM_LEN <value greater then image size>
2. Undef the CONFIG_SYS_BOOTMAPSZ in platform-top.h
Thanks & regards
Aravind
HI thanks for your reply can you please tell me <> bracket how much size i will put and format and after that again i want to build the project??
regards,
k sharmila
