petalinux 2015.4 build error !(error 255,2)
Hi. It is my first time to use petalinux.
I am using ubuntu 17.10 and petalinux 15.4 version.
I followed UG1144 to install petalinux and i made project successfully.
But there were some error during [petalinux-build]
I post screen shot of terminal .
i tried to solve error 255 by following  (https://www.xilinx.com/support/answers/63034.html) ,however it didn't work to me.
Please give me solution for error255 and error2.
Re: petalinux 2015.4 build error !(error 255,2)
Hi @kangsungsik
Ubuntu 17.x is unsupported to install and build petalinux. If you want to install particularly 2015.4 petalinux, here is the older version of ug1144
https://forums.xilinx.com/t5/Embedded-Linux/Ethernet-PHY-KSZ9031RNX/td-p/819201
Best Regards
Shabbir
Hi @kangsungsik
Best Regards
Shabbir
Thank you @shabbirk .
I solve a problem !
