petalinux 2016.2 gpio confusion
Hi Xilinx,
Recently I migrated to Vivado / petalinux 2016.2. One simple test on GPIO is very confusing me. Below is vivado block diagram, just a GPIO with 2 outputs, while GPIO port 1 has one bit output, and GPIO port 2 auto-connecting to LED[7:0].
        axi_gpio_0: gpio@41200000 {
            #gpio-cells = <2>;
            compatible = "xlnx,xps-gpio-1.00.a";
            gpio-controller ;
            reg = <0x41200000 0x10000>;
            xlnx,all-inputs = <0x0>;
            xlnx,all-inputs-2 = <0x0>;
            xlnx,all-outputs = <0x1>;
            xlnx,all-outputs-2 = <0x1>;
            xlnx,dout-default = <0x00000000>;
            xlnx,dout-default-2 = <0x00000000>;
            xlnx,gpio-width = <0x1>;
            xlnx,gpio2-width = <0x8>;
            xlnx,interrupt-present = <0x0>;
            xlnx,is-dual = <0x1>;
            xlnx,tri-default = <0xFFFFFFFF>;
            xlnx,tri-default-2 = <0xFFFFFFFF>;
# ls /sys/class/gpio/
    export gpiochip897 gpiochip906 unexport
# gpio-demo -g 897 -o  2 / 4 / 8 / 16 / 32 / 64 / 128 /256
    which lights each individual LED. However I expect input should be  1 / 2 / 4 / 8 / 16 / 32 / 64 / 128.
Please advise. Thanks in advance.
Voyager
Voyager
Re: petalinux 2016.2 gpio confusion
Hey @exds75
I haven't found the source for gpio-demo but I presume that it will simply map the numbers to the respective GPIOs starting with the GPIO base.
Now the devicetree gpio declaration shows two ports with 1 and 8 bit (GPIOs) so a total of nine GPIOs, which is likely to map the first port to the first GPIO and the second port to the remaining eight GPIOs. So /1/ would end up on the gpio_pin instead of one of the LEDs.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
on zedboard with vivado / petalinux 2016.2
Voyager
Voyager
Hey @exds75
Hope this helps,
Herbert
I added another GPIO, and both GPIOs are setup as single port. Hope not wasting too much PL resource.
Voyager
Voyager
Hey @exds75
The largest part in your design is the AXI interface, so if you really want to reduce PL resource usage, you are better off connecting the LEDs directly to EMIO pins.
Best,
Herbert
Thanks for the suggestion. This is just a simple test. I will use multiple GPIOs as control signaling in a large project.
Voyager
Voyager
You're welcome!
All the best,
Herbert
