Observer icyman
petalinux 2016.4 installation fail
I have installed the petalinux 2016.4 on the Ubuntu 16.04 for several times due to installation fails like as below.
After the installation with this error, there is no files and directories in the components/yocto directory except downloads.
What's wrong with this fail?
INFO: Checking installer checksum...
INFO: Extracting PetaLinux installer...
INFO: Installing PetaLinux...
INFO: Checking PetaLinux installer integrity...
INFO: Extracting Installation files...
INFO: Checking installation environment requirements...
INFO: Installing PetaLinux SDK to "/opt/Xilinx/petalinux-v2016.4-final/."
INFO: Installing PetaLinux zynqMP Yocto SDK to "/opt/Xilinx/petalinux-v2016.4-final/./components/yocto/source/aarch64"...
ERROR: Failed to install Yocto SDK for zynqMP.
Please refer to the PetaLinux Tools Installation Guide.
Check the troubleshooting guide at the end of that manual, and if you are
unable to resolve the issue please contact customer support with file:
/home/icyman/Desktop/petalinux_installation_log
Observer icyman
Re: petalinux 2016.4 installation fail
I solved this issue.
You should use not root account to install the petalinux_installler.
Observer icyman
@icyman
Thanks for updating the resolution.
Yes, user need to have root access to install petalinux.
This is documented in the UG1144 under Installation Requirements.
Achutha
Hello @icyman
I met the same problem as you
Here are my logs:
qwer@ubuntu:~/Desktop/installer/petalinux$ sudo ./petalinux-2016.4-final.run /opt/pkg/petalinux
WARNING: PetaLinux installation directory: /opt/pkg/petalinux/. is not empty!
Please input "y" to continue to install PetaLinux in that directory?[n]y
LICENSE AGREEMENTS
PetaLinux SDK contains software from a number of sources. Please review
the following licenses and indicate your acceptance of each to continue.
You do not have to accept the licenses, however if you do not then you may
not use PetaLinux SDK.
Use PgUp/PgDn to navigate the license viewer, and press 'q' to close
Press Enter to display the license agreements
Do you accept Xilinx End User License Agreement? [y/N] > y
Do you accept Webtalk Terms and Conditions? [y/N] > y
Do you accept Third Party End User License Agreement? [y/N] > y
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
INFO: Installing PetaLinux SDK to "/opt/pkg/petalinux/."
INFO: Installing PetaLinux zynqMP Yocto SDK to "/opt/pkg/petalinux/./components/yocto/source/aarch64"...
PetaLinux Extensible SDK installer version 2016.4
ERROR: The extensible sdk cannot be installed as root.
/home/qwer/Desktop/installer/petalinux/petalinux_installation_log
I used my user account with sudo command, but it failed.
Hi @achutha
I used my default user account with sudo command instead of the root account, but it failed several times.
Here are the logs :
I just don't understand.
If i don't use the sudo command, those files can't be installed to my disk.
Once i used sudo command, it tell me the sdk cannot be installed as root.
What should i do? Re-creating a user account?
Try installing it under your /home directory as a normal user.
Note: To separately install Yocto SDK, download the required .sh file from the link http://downloads.yoctoproject.org/releases/yocto/yocto-2.1/toolchain/x86_64/ and execute the .sh file after setting proper permission "chmod +x".
Debraj
Thank you!
I re-created a normal user and installed the software package in the new /home directory successfully.
Thanks. We will get this clarified in the Petalinux documentation.
Debraj
I've also had this problem and I finally managed to get Petalinux 2016.4 installed by:
* Copying the installer to the home directory
* Running the installer as a normal user (not root, not using sudo)
* Installing it to a directory within my home directory (it never worked when installing to /opt/pkg)
Jeff
Visitor zyxer
The problem seems to be of the location where this is installed, less to do with user account types/permissions. If Xilinx is listening it would be better to avoid such restrictions at least in future releases. Summary is to not try and make good organization of the computer in which it is installed, but just install the way it has been tested. Seriously, I don't want to clutter my /home directory but there is no other option.
Visitor shawnlxf
I met the same problem with you and tried your method, but still failed. (ubuntu14.04)
lxf@sunny-HP-Z640:/home$ sudo ./petalinux-v2016.4-final-installer1.run lxf/petalinux/
Observer fahem
I'm facing a problem with the petlinux2016.4 installation. Actually, every time I try to install it, I get directly this message:
ERROR: Failed to install PetaLinux. Installer checksum checking failed!
ERROR: Expected checksum is "67a57c5e69b25f89ded23830967963ec", actual checksum is "d41d8cd98f00b204e9800998ecf8427e".
I have tried with 2016.3 version then I have downloaded the Petalinux many time however I didn't get any result.
So, please, have you any isea how to fix this problem?
Visitor shawnlxf
Today when I runned the installation like that:
sunny@sunny-HP-Z640:/home/petalinux$ ./petalinux-v2016.4-final-installer1.run .
I installed it successfully but I still don't know the reason why I failed the day before.
Visitor jmairs
I had no problem with checksums matching on Centos7.2 but when I burned the .run installer file to cdrom media and installed it on Redhat 7.2 I get a checksum error: 67a57...
On Redhat I am running
md5sum --v   (8.22)
Perhaps the media is off
hello,If you use the way metioned by all of adviser and also do not work. I suggest you should check whether you creat your target holder using your own account rather root account. And the most important is all operations should be down in your own account not root. And the target folder and installer both be putted in your Home folder. NOT home.
Visitor abhinav6
Hello, For me the following trick helped.
See the problem is that you cannot install SDK as root user or sudo....  So somehow you need the way to install it as a normal user...
So i will recommend you to start fresh remove all previously made directory and strictly follow the commands on user guide UG1144 which is petalinux 2017 guide.
So now make sure that your opt is accessible to normal user so put the following command
sudo chmod 777 /opt
And also your home is accessible so
sudo chmod 777 /home
Note.... Do not change the terminal while writing all these commands...
Now just mkdir without sudo as mentioned in guide UG1144
mkdir -p /opt/pkg/petalinux
Now run the peatalinux executable as mentioned in user guide AGAIN NOT SUDO
cd /my/download-folder, chmod +x petalinux-v2017.1-finalinstaller.run  and
sudo ./petalinux-v2015.4-final-installer-dec.run /opt/PetaLinux.
The install is failing at the final step saying it can't be installed in a root directory and a list of errors like in the above posts, so
I want to run it in the home directory and used the following commands
cd /my/download-folder,chmod +x petalinux-v2017.1-finalinstaller.run and
petalinux-v2017.1-final-installer.run /home/my/Petalinux
but an error command not found is displayed.
It would be nice if i get to know the commands to be followed to run it in my home directory.
These are my commands and i have my petalinux downloads in the downloads folder
my-Ubuntu:~/Downloads$ sudo chmod 777 /opt
my-Ubuntu:~/Downloads$ sudo chmod 777 /home
my-Ubuntu:~/Downloads$ mkdir -p /opt/pkg/petalinux
my-Ubuntu:~/Downloads$ ./petalinux-v2017.1-final-installer.run /opt/pkg/petalinux
But permissions denied is being displayed.
Visitor akkudub
On a shared server, giving users access to the entire /opt can be less than ideal, so I did this and it worked:
cd /opt
sudo mkdir -p pkg/petalinux
sudo chown -R [OWNER]:[GROUP] pkg
Replace the [OWNER]  and [GROUP] with your own username and group.
Hope this helps! I really wish they'd include something like this in the documentation. Or at least do some permission checks BEFORE they do the time consuming extraction and checksum so we don't have to wait freaking 15 minutes before we try again.
Participant diegosantibanez
I had problems installing petalinux 2017.2 into opt/pkg/petalinux.
The only thing that finally worked for me was:
sudo mkdir -p opt/pkg/petalinux
sudo chmod 777 opt/pkg/petalinux
./petalinux-v2017.2-final-installer.run opt/pkg/petalinux
Diego.
Hitting the same exact problem with 2017.2 ... this is really an issue with the installation system, and how permissions are set.
My home directory is a network drive, and I don't want to install the tool on a remote drive... that makes it incredibly slow.
I wish I could: sudo apt-get install petalinux
Here is how I am getting this to work in Ubuntu 16.04:
sudo mkdir  /opt/pkg
sudo mkdir  /opt/pkg/petalinux-v2017.2
sudo chown <username> /opt/pkg/petalinux-v2017.2
Copy the *.run installer to /opt/pkg/petalinux-v2017.2/
cd /opt/pkg/petalinux-v2017.2/
It won't work if you run with sudo.. it will fail at the Yocto stage.
This can be hard even if you work at Xilinx... :-)
