petalinux 2016.4 qemu boot errot
my petalinux 2016.4 qemu boot with the follow error,but it is ok for the xilinx zc702 BSP pre-build qemu boot:
INFO: No DTB has been specified, use the default one "/home/iot/Downloads/work164/petalinuxproj/bus_standard/bus_standard/images/linux/system.dtb".
INFO: TCP PORT is free
INFO: Starting arm QEMU
INFO: qemu-system-aarch64 -M arm-generic-fdt-plnx -machine linux=on -serial /dev/null -serial mon:stdio -display none -kernel /home/iot/Downloads/work164/petalinuxproj/bus_standard/bus_standard/images/linux/u-boot.elf -gdb tcp::9000 -dtb /home/iot/Downloads/work164/petalinuxproj/bus_standard/bus_standard/images/linux/system.dtb -net nic,vlan=1 -net user,vlan=1 -net nic -net nic -net nic -net nic -net nic -net nic -net nic -tftp /tftpboot -device loader,addr=0xf8000008,data=0xDF0D,data-len=4 -device loader,addr=0xf8000140,data=0x00500801,data-len=4 -device loader,addr=0xf800012c,data=0x1ed044d,data-len=4 -device loader,addr=0xf8000108,data=0x0001e008,data-len=4
qemu-system-aarch64: -tftp /tftpboot: The -tftp option is deprecated. Please use '-netdev user,tftp=...' instead.
ERROR:/build/ssw/petalinux/jenkins/new_build_yocto_src_2016.4/qemu/qom/object.c:1576:object_get_canonical_path_component: assertion failed: (obj)
petalinux-qemu-boot: line 726: 41031 Aborted (core dumped) $QEMU_DEBUG ${qemu_cmd} ${qemu_mach} ${nic_list} ${qemu_serial} ${qemu_display} ${qemu_img_opt} -gdb tcp::${start_port} ${dtb_option} ${slirp_option} ${extra_args} ${zynq_fsbl_args} ${aarch64_beta2_args}
Re: petalinux 2016.4 qemu boot errot
Were you able to solve this issue?
I feel you are not using zynqmp-qemu-arm.dts file in your qemu command. Let me know if you are still facing this issue?
Best Regards
Shabbir
thank you for you reply.
it was ok when petalinux-boot --qemu boot in the xilinx xilinx-zc702-2016.4 project.
but when i petalinux-boot --qemu --u-boot my own project it was error.
i use the zynq zc702 board. and i has change the dts. i do not know what you mean "zynqmp-qemu-arm.dts zynqmp-qemu-arm.dts file in your qemu command". i just change the meta-user/recipes-dt file and do not change  other dts file. and use the petalinux-boot --qemu --u-boot ,petalinux-boot --qemu --kernel command like the ug1144.
Visitor wmyan2010
@shabbirk
Hi~
I also met the same problem. The problem details is shown in my post:
link: https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-fails-to-boot-on-QEMU/td-p/805730
I wonder to know what you mean "using zynqmp-qemu-arm.dts file in your qemu command" ?
Best regards,
Wu
