Newbie dwallis
petalinux 2017.2 - can't use openssh instead of dropbear
My last post seemed to disappear so I am re-posting my issue.  This concerns the petalinux 2017.2 release for the zcu102 board.
When I disable all dropbear references in petalinux-config -c rootfs, the petalinux-build still attempts to include it.
In 2016.4, I was able to disable all dropbear references and enable openssh instead.
When I try this with 2017.2, the build process gives me this error:
Computing transaction...error: Can't install packagegroup-core-ssh-dropbear-1.0-r1@all: unable to install provider for dropbear:
error: dropbear-2016.74-r0@aarch64 is conflicted by openssh-7.3p1-r0@aarch64
I have verified all dropbear references have been disabled from the rootfs configuration:
Symbol: dropbear [=n]
Symbol: dropbear-dbg [=n]
Symbol: dropbear-dev [=n]
Symbol: dropbear-openssh-sftp-server [=n]
Symbol: packagegroup-core-ssh-dropbear [=n]
Symbol: packagegroup-core-ssh-dropbear-dbg [=n]
I saw this same issue with 2017.1, but was hoping it would be fixed in 2017.2...  Any ideas on how to fix this?
Re: petalinux 2017.2 - can't use openssh instead of dropbear
I've got the same problem.  Any update?
I went into:
meta-petalinux/recipes-core/images/petalinux-image-common.inc
and deleted ssh-server-dropbear from the COMMON_FEATURES variable.  Rebuilt it and things are what I expect now.
Confirmed the previous reply fixes the issue. Only additional comment is the full path to the file is:
$PATH_TO_PETALINUX_INSTALL/components/yocto/sources/aarch64/layers/meta-petalinux/recipes-core/images/petalinux-image-common.inc
One thing that should also work... Add the following line to <project>/project-spec/meta-user/conf/layer.conf:
COMMON_FEATURES_remove = "ssh-server-dropbear"
This way the Petalinux installation directory doesn't have to be modified. Then you should be able to add openssh (ie, IMAGE_INSTALL_append = " openssh") without conflict.
> add this  IMAGE_FEATURES_remove += "ssh-server-dropbear" in meta-user/conf/petalinuxbsp.conf
>  unselect packagegroup-dropbear, select openssh and openssh-server  from petalinux-config -c rootfs
