petalinux 2017.4 petalinux-build error
when run petalinux-build build the system, there have error message. here is part of the message:
WARNING: petalinux-user-image-1.0-r0 do_rootfs: log_check: There were error messages in the logfile
WARNING: petalinux-user-image-1.0-r0 do_rootfs: log_check: Matched keyword: [ERR]
ERROR: petalinux-user-image-1.0-r0 do_rootfs:
ERROR: ld.so: object 'libpseudo.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
DEBUG: Shell function set_user_group finished
NOTE: Executing write_image_manifest ...
DEBUG: Executing python function write_image_manifest
DEBUG: Python function write_image_manifest finished
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/one/xilinx/myPetalinux/ax7010_ov5640/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/temp/log.do_rootfs.14231
ERROR: Task 9 (/home/one/xilinx/myPetalinux/ax7010_ov5640/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb, do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1790 tasks of which 1789 didn't need to be rerun and 1 failed.
i have find some topic ,but didnot passed.
thanks.
Re: petalinux 2017.4 petalinux-build error
Please make sure you have followed the installation requirements as per UG1144 guide while installing petalinux
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1144-petalinux-tools-reference-guide.pdf
Best Regards
Shabbir
in addition to this, i found that libgtk2.0-dev was also required, I ran into a similar issue and just installing that solved it.
