petalinux 2017.4 usb1 init fail
Hello all,
I try to use usb1 at FPGA XC7z020 and build the system at petalinux 2017.4.
Below is my device tree that reference to http://www.wiki.xilinx.com/Zynq+Linux+USB+Device+Driver.
chosen {
stdout-path = "serial0:115200n8";
aliases {
ethernet0 = &gem0;
ethernet1 = &gem1;
serial0 = &uart1;
serial1 = &uart0;
usb_phy1:usb_phy@1 {
compatible = "ulpi-phy";
#phy-cells = <0>;
reg = <0xe0003000 0x1000>;
view-port = <0x170>;
drv-vbus;
usb-reset = <&gpio0 7 1>;
&usb1{
dr_mode = "peripheral";
usb-phy = <&usb_phy1>;
Below is system boot USB init fail information
Board: Xilinx Zynq
I2C: ready
DRAM: ECC disabled 480 MiB
MMC: Card did not respond to voltage select!
sdhci@e0101000 - probe failed: -95
SF: Detected s25fl128s_64k with page size 256 Bytes, erase size 64 KiB, total 16 MiB
In: serial
Out: serial
Err: serial
Net: ZYNQ GEM: e000b000, phyaddr 0, interface rgmii-id
eth0: ethernet@e000b000ZYNQ GEM: e000c000, phyaddr 1, interface rgmii-id
PHY is not detected
GEM PHY init failed
device 0 offset 0x520000, size 0xa80000
SF: 11010048 bytes @ 0x520000 Read: OK
## Loading kernel from FIT Image at 01000000 ...
Using 'conf@1' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@0' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x010000d4
Data Size: 3747432 Bytes = 3.6 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha1
Hash value: 63fc2d1697aab749c54e4fb83c10d4105f147007
## Loading ramdisk from FIT Image at 01000000 ...
Trying 'ramdisk@0' ramdisk subimage
Description: ramdisk
Type: RAMDisk Image
Data Start: 0x01396ee0
Data Size: 7098564 Bytes = 6.8 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 43dbda9b75bec18524506c1785c65f5d7d3d9113
## Loading fdt from FIT Image at 01000000 ...
Trying 'fdt@0' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x01393030
Data Size: 15869 Bytes = 15.5 KiB
Architecture: ARM
Hash algo: sha1
Hash value: 6306b9b65d20781d8657ae46b43a7f5e04589dda
Booting using the fdt blob at 0x1393030
Loading Kernel Image ... OK
Loading Ramdisk to 07a3a000, end 080ff0c4 ... OK
Loading Device Tree to 07a33000, end 07a39dfc ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 4.9.0-xilinx-v2017.4 (hans@hans-VirtualBox) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Tue May 22 15:51:05 CST 2018
OF: fdt:Machine model: xlnx,zynq-7000
bootconsole [earlycon0] enabled
cma: Reserved 16 MiB at 0xbf000000
Memory policy: Data cache writealloc
percpu: Embedded 14 pages/cpu @dc8d1000 s25932 r8192 d23220 u57344
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 384064
Kernel command line: console=ttyPS0,115200 earlyprintk
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 1494476K/1540096K available (6144K kernel code, 200K rwdata, 1460K rodata, 1024K init, 229K bss, 29236K reserved, 16384K cma-reserved, 1032192K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xde800000 - 0xff800000 ( 528 MB)
lowmem : 0xc0000000 - 0xde100000 ( 481 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0700000 (7136 kB)
.init : 0xc0900000 - 0xc0a00000 (1024 kB)
.data : 0xc0a00000 - 0xc0a32000 ( 200 kB)
.bss : 0xc0a32000 - 0xc0a6b698 ( 230 kB)
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to de800000
slcr mapped to de802000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at de802100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at de80a000, irq=17
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Setting up static identity map for 0x100000 - 0x100058
Brought up 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xde880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0000000.serial: ttyPS1 at MMIO 0xe0000000 (irq = 27, base_baud = 3125000) is a xuartps
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 28, base_baud = 3125000) is a xuartps
`▒▒k▒▒▒▒[ttyPS0] enabled
console [ttyPS0] enabled
bootconsole [earlycon0] disabled
GPIO IRQ not connected
XGpio: /amba_pl/gpio@41210000: registered, base is 1014
XGpio: /amba_pl/gpio@41200000: registered, base is 1012
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
fpga-region fpga-full: FPGA Region probed
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Freeing initrd memory: 6936K (c7a3a000 - c8100000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=30 max_order=19 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler noop registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to de8c1000
[drm] Initialized
brd: module loaded
loop: module loaded
m25p80 spi0.0: found s25fl128s, expected n25q512a
m25p80 spi0.0: s25fl128s (16384 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000fa0000 : "kernel"
0x000000fa0000-0x000001000000 : "spare"
libphy: Fixed MDIO Bus: probed
CAN device driver interface
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 31 (00:0a:35:00:1e:55)
Marvell 88E1510 e000b000.etherne:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=e000b000.etherne:00, irq=-1)
macb e000c000.ethernet eth1: Cadence GEM rev 0x00020118 at 0xe000c000 irq 32 (00:0a:35:00:c0:38)
Generic PHY e000c000.etherne:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=e000c000.etherne:00, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci-pci: EHCI PCI platform driver
ci_hdrc ci_hdrc.0: unable to init phy: -110
ci_hdrc: probe of ci_hdrc.0 failed with error -110
Does anyone have the idea?
