petalinux 2018.1 build failure
Trying to build petalinux 2018.1, I have diasbled binutils, cairo in filesystems->devel. But by default it is trying to fetch those packages but it is unable to fetch those packages and build is getting failed.
How to resolve this issue. Your immediate suggestions/solution is required.
Umamahesh
Re: petalinux 2018.1 build failure
Hi @umamahesh
I just want to know is it building your project without disabling any package.
and let me know exactly what package you would like to disable and build it.
Thanks & regards
Aravind
Hi Aravind,
As mention two packages (binutils and cairo )are already disabled in rootfs (using petalinux-config -c rootfs), but it is trying to fetch those packages automatically during petalinux-build and getting failed. PFA log for reference.
Hi @umamahesh
By default   this packages((binutils and cairo) are not enabled in the petalinux BSP.
I am able to build at myend. You no need to disable this packages explicitly. I just want to know, is your build setup is working ?.
and Can you build the BSP without modifying anything. Just to cross check your build setup.
Thanks & regards
Aravind
Even in my build it is not enabled,but it is trying to fetch and unable to resolve too. I created fresh project and continued my build.
