sonadrin
petalinux 2018.2 boot failure
Hi, I have the exact same problem like this guys here :
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-boot-with-JTAG/td-p/713472/highlight/true?device-view=desktop
I use windows 10 with ubuntu 16.04 vmware machine.
I did everything in the pdf - ug1144 to install petalinux in the vm machine and boot it on the Zedboard evaluation kit (Zynq7000).
I did the command : "petalinux-boot --jtag --prebuilt 3"
and it sends me this log :
WARNING: Will not program bitstream on the target. If you want to program bitstream,
WARNING: please run petalinux-package --prebuilt to put the bitstream to the prebuitl directory,
WARNING: or use --fpga --bitstream option to specify a bitstream.
INFO: Append dtb - /home/dorubuntu/petalinux_projects/zynq7000_petalinux/pre-built/linux/images/system.dtb and other options to boot zImage
INFO: Launching XSDB for file download and boot.
INFO: This may take a few minutes, depending on the size of your image.
rlwrap: warning: your $TERM is 'xterm-256color' but rlwrap couldn't find it in the terminfo database. Expect some problems.: Inappropriate ioctl for device
no targets found with "name =~ "arm*#0"". available targets: none
while executing
"error "no targets found with \"$params(filter)\". available targets:$target_list""
(procedure "targets" line 177)
invoked from within
"targets -set -nocase -filter {name =~ "arm*#0"}"
(file "/tmp/tmp.BYPFZlDvkn" line 3)
INFO: The XSDB log is as follows
attempting to launch hw_server
****** Xilinx hw_server v2018.2
**** Build date : Jun 14 2018-20:18:37
** Copyright 1986-2018 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
some other comments about the problem :
I use vivado 2018.2 hardware server to connect the jtag to the vm machine.
It works perfectly fine in SDK and Vivado.
I did read anything on the post I added and in the end the guy with the problem said he solved it by "Build the jtag dev rules".
I don't know what it means and when I looked it up I could find anything useful to build those rules.
He said that it worked for him only if the jtag could be scanned as non-root user, which again I don't know how to do it.
Thank you everyone who reads this!
I have a similar problem with Petalinux 2018.2. When I program the Zynq 7000 SoC with FPGA bitstream using Windows SDK 2018.2 or Vivado, it works. I am able to test the connecion to hw_server in SDK.
However it doesnt work when I try to program from the linux VM using SDK 2018.2.
I get the following error too:
no targets found with "name =~ "ARM*#0"". available targets: none
while executing
invoked from within
"targets -set -filter {name =~ "ARM*#0"}"
I would greatly appreciate your help.
Thank you ver much in advance!
