jaontolt
(petalinux 2018.3) Permission error while config kernel
hi,
I use CentOS7.3 to run petalinux 2018.3. The shell is bash.
I was created a hdf and import to my project (base on zcu104-v2018.3).
There is no error when I run petalinux-config and petalinux-build. I test the BOOT.BIN, it can boot linux on my board and works fine.
Now I need to change kernel configuration to support OpenAMP.
Petalinux throw a execption while running command "petalinux-config -c kernel".
The attachment config.log is log file of petalinux-config.
The attachment do_menuconfig.log is log file of kernel do menuconfig.
Can anyone help me solve this issue? Thanks.
shabbirk
Hi @jaontolt
May I know what changes you have done to enable OpenAMP in petalinux-config?
I will try to see if I can reproduce the similar issue at my end accordingly
Best Regards
Shabbir
