petalinux 2018.3 build failure
Hello there,
  • I have my board SOC hdf file ready.
petalinux-create was OK
petalinux-config --get-hw-description=< path-to-my-hdf-folder > was OK
petalinux-build failed:Capture.JPG
Something related with xlnk, it seems... can anyone help?
回复: petalinux 2018.3 build failure
Hi, @guidopc
Have you configured the kernel before building it?
Maybe you can disable APF dirver by "petalinux-config -c kernel"
Here is another workaround that you can try.
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-XLNK-compile-error/td-p/900950
This worked in my case:
  • petalinux-config -c kernel
then
Device Drivers -> Staging drivers
Device Drivers -> Staging drivers -> Xilinx APF Accelerator Driver
Device Drivers -> Staging drivers -> Xilinx APF Accelerator Driver -> Yes
Device Drivers -> Userspace I/O Drivers
Device Drivers -> Userspace I/O Drivers -> Userspace I/O platform driver with generic IRQ handling
Device Drivers -> Userspace I/O Drivers -> Userspace I/O platform driver with generic IRQ handling -> Yes
make sure they are enabled with a * rather than an M,  then save and exit
