Visitor brianwtec
petalinux 2018.3 configure error.
I've installed petalinux 2018.3 on my gentoo laptop and it installed fine, except I did get a few messages about bad index or something like that.
I downloaded the ZC702 bsp and created a new project with petalinux.
However, when I run petalinux-configure, I get the following error messages:
~/petalinux_project/test $ petalinux-config
[INFO] generating Kconfig for project
[INFO] menuconfig project
ERROR: Failed to menu config project component
ERROR: Failed to config project.
Unfortunately, the verbose option doesn't produce more information about the failure message. I figure there is a missing dependency, but I checked the list of dependencies and they are all installed in both 64 bit and 32 bit versions.
Hmmm, just had a thought, maybe the 32 bit versions aren't accessible through the LD_LIBRARY_PATH... I'll check that out.
If anyone has any suggestions, I'd really appreciate it.
Tags (3)
Re: petalinux 2018.3 configure error.
please check the installation requirements chapter in ug1144-petalinux-tools-reference-guide.pdf. For example libncurses5-dev will provide the menuconfig.
However Gentoo is not officially supported by petalinux (see the same chapter), so expect further trouble.
I recommend to use one of the officially supported linux distributions (in a virtual machine if necessary).
Hope that helps.
Sebastian
