Re: petalinux-2018.3 installation on ubuntu 16.04.03
Great! Thank you very much!
Hi Puja,
Please follow the Document UG1144 for petalinux installation gude . This i svery good document.
regards,
Raghuram
In order to fast ramp up with Ubuntu of my ZCU-102 Rev 1.1 EVB.
Is there Link for downloading img of pre-built  of petalinux-v2018.3- run ubuntu or CentOS that tested and working ?
Eli
In short run the below command for Ubuntu 16.04.3 (as per Table 2-1: Packages and Linux Workstation Environments):
apt install dos2unix iproute2 gawk git make net-tools libncurses5-dev tftpd zlib1g:i386 libssl-dev flex bison libselinux1 gnupg wget diffstat chrpath socat xterm autoconf libtool tar unzip texinfo zlib1g-dev gcc-multilib build-essential libsdl1.2-dev libglib2.0-dev screen pax gzip
How did you solved it?
Installing all the dependencies in Table 2-1: Packages and Linux Workstation Environments under the column (Ubuntu 16.04.3) solves the issues during installation.
For e.g. if any dependency is not pre-installed (or even not right version e.g gawk), the installer doesn't throw error directly, instead the installer fails with an indirect message like "bad address"
So better make sure the the listed dependencies are met before running the installer.
How was the original issue with the installation error resolved? @raghuram1a
can u please tell me how did u solve the awk: read error (Bad address) because i am stuck in the same problem and i cannot find a solution
Install the below dependencies as listed in PetaLinux Tools Documentation Reference Guide
Chapter 2:
for e.g. Ubuntu:
sudo apt-get install -y gcc gawk git make net-tools libncurses5-dev tftpd zlib1g-dev libssl-dev
texinfo zlib1g-dev gcc-multilib build-essential libsdl1.2-dev libglib2.0-dev zlib1g:i386
Also ensure you have reconfigured sh to bash
ls -l /bin/sh -> dash : Wrong
ls -l /bin/sh -> bash : Correct
If you system is not configured for bash, run
sudo dpkg-reconfigure dash
and select <No> in the window
This solves the awk bad address error and installation issues.
i got the same error, how you reolve it please help me.
Have you pressed enter for "Press Enter to display the license agreements"?
Hi, How did you solve this error?
I have tried updating all the prerequisites. Still i get the error.
 I am getting the same error now.
Could you please tell me what must be done to resolve it?
原因:在ubuntu中已经取消掉了gmake,都用make代替。解决: sudo apt-get install gawk
hi,
I encountered the same problem as you, how did you solve it in the end
Run the comman
sudo apt install gawk
Then try to run the installer.
This solved my problem.
yes, you can input "sudo apt-get install gawk".this can do.
