Visitor psocbee
petalinux-2018.3 on ZCU104 fails to access the GPIO expander
when i switched my ZCU104 project from petalinux-2018.2 to petalinux-2018.3 the following error message appeared during Linux boot:
"[    6.593450] pca953x 0-0021: failed reading register"
Actually the GPIO expander chip U97 on the ZCU104 is not detected and the on-board GPIOs are not not available. With petalinux-2018.2 it works correctly. Further investigation showed that the GPIO expander chip on the ZCU104 board is hard wired to I2C address 0-0020 but petalinux-2018.3 probes the GPIO chip at I2C address 0-0021. This seems to be an issue of the ZCU104 petalinux-2018.3 board support package.
Any idea how to reconfigure the correct address for the ZCU104 GPIO expander chip when using the petalinux-2018.3 bsp?
Visitor psocbee
Re: petalinux-2018.3 on ZCU104 fails to access the GPIO expander
There is a bug in the device tree description file zcu104-revc.dtsi (petalinux 2018.3):
&i2c1 {
    tca6416_u97: gpio@21 {          /* bug: this should be gpio@20 */
        compatible = "ti,tca6416";
        reg = <0x21>;               /* bug: this sould be <0x20> */
        gpio-controller;
        #gpio-cells = <2>;
This can be fixed with the following entry in
<project-dir>/project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
   bug-fix: wrong i2c address for tca6416_u97
   petalinux 2018.3 defines i2c address 0x21 in file zcu104-revc.dtsi
   but it should be 0x20
&i2c1 {
    tca6416_u97: gpio@20 {
        reg = <0x20>;
        gpio-controller;
        #gpio-cells = <2>;
    /delete-node/ gpio@21;
Visitor psocbee
&i2c1 {
        gpio-controller;
        #gpio-cells = <2>;
&i2c1 {
        reg = <0x20>;
        gpio-controller;
        #gpio-cells = <2>;
