Visitor chen8494
petalinux 2019.1 Cortex-R5 has no power
Hello
when i use zcu102 borad .I create a project ,petalinux 2019.1 and it boot from SD , the APU work well.
then i create bare-metal applications for RPU in SDK . but it does not work .
I input targets in the xsct console,it show R5 has no power.
xsct% targets
1 PS TAP
2 PMU
3 PL
4 Legacy Debug Hub
5 PSU
6 RPU (Reset)
7 Cortex-R5 #0 (No Power)
8 Cortex-R5 #1 (No Power)
9 APU
10 Cortex-A53 #0 (Running)
11 Cortex-A53 #1 (Running)
12 Cortex-A53 #2 (Running)
13 Cortex-A53 #3 (Running)
I used petalinux 2018.2 before, and RPU works normally, so why petalinux 2019.1 RPU has no power?
thanks!
Re: petalinux 2019.1 Cortex-R5 has no power
I am not sure if the target CPU was set to RPU, would you check the BIF or
add the –cpu option like following.
--add images/linux/zynqmp_r5_app.elf --cpu r5-0
And pleaes enable the FSBL debug print to see if r5 app is loaded by FSBL.
project-spec\meta-plnx-generated\recipes-bsp\fsbl\fsbl_%.bbappend
then add below content:
XSCTH_BUILD_DEBUG = "1"
XSCTH_COMPILER_DEBUG_FLAGS = "-DFSBL_DEBUG_DETAILED"
if this is still not working, try to set ENABLE_UNUSED_RPU_PWR_DWN flag to 0 while compiling PMUFW, If you do not want to power down RPU by default.
I don’t see any issue from my side.
How do you run r5 app in SDK, from GUI or XSDB?
If you run from xsdb, try to tagert on RPU then “rst -processor”
Visitor chen8494
thank you for relpay!
I run r5 app in SDK, from GUI.
when linux boot before this picture,i send 'target' in the xsct console ,it show rpu works well.
xsct% target
1 PS TAP
2 PMU
3 PL
5 PSU
6 RPU
7 Cortex-R5 #0 (Halted)
8 Cortex-R5 #1 (Lock Step Mode)
9 APU
11 Cortex-A53 #1 (Power On Reset)
12 Cortex-A53 #2 (Power On Reset)
13 Cortex-A53 #3 (Power On Reset)
when linux boot finish ,i send 'target' in the xsct console ,it show rpu has no poower
xsct% target
1 PS TAP
2 PMU
3 PL
5 PSU
6 RPU (Reset)
9 APU
this is my boot log
thanks
Visitor chen8494
I also try rst -processor
xsct% target
1 PS TAP
2 PMU
3 PL
5 PSU
6 RPU (Reset)
9 APU
xsct% target 7
xsct% rst -processor
xsct% APB AP transaction error, DAP status 30000021
I think Linux is now aware of RPU if you are loading it from JTAG. So close the RPU power.
Please add the R5 elf file to the bootimage, it should be no problem.
Visitor chen8494
thanks for your suggestion!
I try this by
petalinux-package --boot --fsbl zynqmp_fsbl.elf --fpga system.bit --pmufw pmufw.elf --atf bl31.elf --u-boot u-boot.elf --add rpu_app.elf --force
but the RPU also has no power
or by SDK ,and the linux can not boot,just print this.
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1 Jun 12 2019 - 08:24:04
Visitor chen8494
I regenerate the BOOT.bin by --add images/linux/zynqmp_r5_app.elf --cpu r5-0
The APU and RPU all can work !
ENABLE_UNUSED_RPU_PWR_DWN  need to compiling PMUFW in SDK ,so i don't try this method.
thank you very much!
