petalinux 2019.1 fpga manager causes build error
hi,
i have enabled the fpga manager in petalinux-config and
i have given him the folder containing .hdf file
during petalinux-build i get this error
| ls: cannot access '........petalinux_03/build/tmp/work/plnx_zynqmp-xilinx-linux/fpga-manager-util/xilinx+gitAUTOINC+73e546e312-r0/recipe-sysroot/boot/bitstream/*': No such file or directory
| WARNING: exit code 2 from a shell command.
| ERROR: Function failed: do_compile (log file is located at .......petalinux_03/build/tmp/work/plnx_zynqmp-xilinx-linux/fpga-manager-util/xilinx+gitAUTOINC+73e546e312-r0/temp/log.do_compile.26555)
Re: petalinux 2019.1 fpga manager causes build error
Hi @mamisadegh3
Can you do a petalinux-build -x mrproper, and retry?
That did not solve the issue.
but i did something silly and it worked! i copied the files there manually! i am not sure if this is a good approach.
Visitor tbrooks
I ran into this problem @mamisadegh3 . For me, I had forgotten to tick the "include bitstream" box when exporting the hardware in Vivado.
Capture.JPGTick the box!
