petalinux 2019.1 "petalinux-build" (wrong ELF class: ELFCLASS64)
Hi All,
I'm using petalunx 2019.1 on Ubuntu 18.04.
I can't configure the kernel. Message after petalinux-build is:
ERROR: petalinux-user-image-1.0-r0 do_rootfs: [log_check] petalinux-user-image: found 1 error message in the logfile:
[log_check] ERROR: ld.so: object '/lib/$LIB/liblsp.so' from /etc/ld.so.preload cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/user/project/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/temp/log.do_rootfs.13921
ERROR: Task (/home/user/project/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb:do_rootfs) failed with exit code '1'
What could be wrong?
Hi playclose4@yahoo.com
Would you share the following file ?
/home/svc/xproject/fmc130e_v12_z045_fm212x1g8/project/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/petalinux-user-image/1.0-r0/temp/log.do_rootfs.13921
Best regards,
File attached
Would you execute the following command before building rootfs ?
$ unset LD_PRELOAD
Best regards
I did unset LD_PRELOAD. No result.
But at first, I did it with default kernel build settings and successfully built project. Then I repeat it with my settings and got an error as same as it was.
Could you tell me what OS (distributor) do you use on your host ? Ubuntu 18.04?
Best regards,
Ubuntu 18.04
Would you share the followings ?
$ echo $LIB
$ ls -lA /etc/ld.so*
$ cat /etc/ld.so.preload
Best regards,
watari
$ echo $LIB
-rw-r--r-- 1 root root 141811 Oct 14 16:13 /etc/ld.so.cache
-rw-r--r-- 1 root root 34 Jan 27 2016 /etc/ld.so.conf
-rw-r--r-- 1 root root 20 Oct 14 16:07 /etc/ld.so.preload
/etc/ld.so.conf.d:
total 24
-rw-r--r-- 1 root root 38 Jan 8 2018 fakeroot-x86_64-linux-gnu.conf
-rw-r--r-- 1 root root 168 Apr 17 2018 i386-linux-gnu.conf
-rw-r--r-- 1 root root 44 Jan 27 2016 libc.conf
-rw-r--r-- 1 root root 100 Apr 17 2018 x86_64-linux-gnu.conf
-rw-r--r-- 1 root root 56 Apr 17 2018 zz_i386-biarch-compat.conf
-rw-r--r-- 1 root root 58 Apr 17 2018 zz_x32-biarch-compat.conf
/lib/$LIB/liblsp.so
