04-06-2021 10:51 PM
I am trying to boot my custom board based zynq-mp device using QSPI mode,
I am Generating BOOT.BIN using below command.
petalinux-package --force --boot --fsbl zynqmp_fsbl.elf --u-boot --fpga ../../../zcu.bit --pmufw pmufw.elf
The problem is when I load image.ub(Kernel image) it on the QSPI flash I get the error described above. The full bootlog can be found below:
ZynqMP>boot
SF: Detected n25q512a with page size 256 Bytes, erase size 64 KiB, total 64 MiB
device 0 offset 0x3e80000, size 0x80000
SF: 524288 bytes @ 0x3e80000 Read: OK
## Executing script at 20000000
Wrong image format for "source" command
SCRIPT FAILED: continuing...
No MMC device available
no devices available
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
Device 0: unknown device
starting USB...
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-zynqmp-zynqmp
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB...
No ethernet found.
No ethernet found.
booting the petalinux failed with the messages below:
ZynqMP> bootm
Wrong Image Format for bootm command
ERROR: can't get kernel image!
04-07-2021 12:29 PM
did you copy the boot.scr to the sd card too?
You can use the bootm command, however you need to provide the address of the kernel
For example:
Reference:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842223/U-boot
