petalinux 2020.1 question
In petalinux 2019.2 , there are many layer files under <plnx-path>/components/yocto/source/aarch64/layers/ .
But in petalinux 2020.1, there are no any layer files under <plnx-path>/components/yocto/source/aarch64/layers/ .
How can I see those files in petalinux 2020.1?
Sitting
Hi @sitting ,
Yes, as mentioned by @jcabel  petalinux is build out of yocto's most stable release. And we use yocto and its not a part of our development.
Thanks & Regards,
Shubhangi
I don't think you will have any answer from Xilinx as they don't develop Yocto.
Hi @sitting ,
Thanks & Regards,
Shubhangi
