11-25-2020 06:22 AM
I'm working with petalinux 2020.2 but I've a problem with the device-tree, after
petalinux-config --get-hw-description=.
I configure the device-tree using this command
petalinux-config -c device-tree
but I get these errors:
Log data follows:
| DEBUG: Executing python function externalsrc_configure_prefunc
| DEBUG: Python function externalsrc_configure_prefunc finished
| DEBUG: Executing shell function do_configure
| MISC_ARG is -hdf_type xsa -yamlconf /home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+git999-r0/device-tree.yaml
| APP_ARG is -app "device-tree"
| Using xsct from: /home/andrea/xilinx/petalinux2020_2/tools/xsct//bin/xsct
| cmd is: xsct -sdx -nodisp /home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+git999-r0/dtgen.tcl -ws /home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/project-spec/configs/../../components/plnx_workspace/device-tree -pname device-tree -rp /home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/components/yocto/workspace/sources/device-tree -processor psu_cortexa53_0 -hdf /home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/build/tmp/deploy/images/zynqmp-generic/Xilinx-zynqmp-generic.xsa -arch 64 -app "device-tree" -hdf_type xsa -yamlconf /home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+git999-r0/device-tree.yaml
| INFO: [Hsi 55-2053] elapsed time for repository (/home/andrea/xilinx/petalinux2020_2/tools/xsct/data/embeddedsw) loading 0 seconds
| WARNING: label 'amba_apu' found in existing tree
| WARNING: quotes to be removed or use 2018.1 version for &sata params param0..param7
| WARNING: hdmi_v_hdmi_tx_ss_0 pin AUDIO_IN is not connected... check your design
| WARNING: psu_usb_xhci_0: No reset found
| WARNING: label 'usb0' found in existing tree
| WARNING: Only boolean type can have empty value. Fail to add driver(sfp_10G_xxv_ethernet_0) property(axistream-connected) type(reference) value()
| WARNING: Please add the property manually
| WARNING: Only boolean type can have empty value. Fail to add driver(sfp_10G_xxv_ethernet_0) property(axistream-control-connected) type(reference) value()
| WARNING: quotes to be removed or use 2018.1 version for sfp_10G_xxv_ethernet_0:ethernet@a0042000 param xlnx,num-queues
| can't read "end_mappings": no such variable
| ERROR: [Hsi 55-1545] Problem running tcl command ::sw_device_tree::post_generate : can't read "end_mappings": no such variable
| while executing
| "dict exists $end_mappings $inip"
| (procedure "update_endpoints" line 658)
| invoked from within
| "update_endpoints $drv_handle"
| ("foreach" body line 3)
| invoked from within
| "foreach drv_handle [get_drivers] {
| gen_peripheral_nodes $drv_handle
| (procedure "::sw_device_tree::post_generate" line 6)
| invoked from within
| "::sw_device_tree::post_generate device_tree"
| ERROR: [Hsi 55-1443] Error(s) while running TCL procedure post_generate()
| hsi::generate_target: Time (s): cpu = 00:00:06 ; elapsed = 00:00:07 . Memory (MB): peak = 1895.531 ; gain = 0.000 ; free physical = 38887 ; free virtual = 186285
| generate_target failed
| while executing
| "error "generate_target failed""
| invoked from within
| "if {[catch {hsi generate_target -dir $project} res]} {
| (file "/home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+git999-r0/dtgen.tcl" line 38)
| WARNING: exit code 1 from a shell command.
| ERROR: Execution of '/home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/build/tmp/work/zynqmp_generic-xilinx-linux/device-tree/xilinx-v2020.2+git999-r0/temp/run.do_configure.22540' failed with exit code 1:
| while executing
| invoked from within
| invoked from within
| invoked from within
| while executing
| invoked from within
ERROR: Task (/home/andrea/Documenti/petalinuxProjects/2020.2/TLxDec/components/yocto/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2222 tasks of which 2212 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build device-tree
How can I fix this problem?
thanks, Andrea
12-11-2020 06:50 AM
12-25-2020 03:34 AM
This may be the clue for this issue. Please check if the below two property in generated device tree are not assigned any value. You can add them in system-user.dtsi if they are not set.
axistream-connected axistream-control-connected
You can refer to this wiki page about the device tree for 10G/25G ethernet core.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842485/Linux+AXI+Ethernet+driver
