o02
petalinux 2020.2 version booting issue
Has anyone run ubuntu on PETALINUX 2020.2 with the run_desktop command?
It worked well in 2019.2 version, but in 2020.2 version, booting stops as shown in the picture below.
The board is using the ZCU106.
watari
Hi @o02
Would you upgrade u-boot to 2020.2 ?
Best regards,
o02
Can you tell me how to upgrade?
watari
Hi @o02
I don't know how to build u-boot (2020.1) and kernel (2020.2) between different version.
I only know build procedure with same version.
So, would you upgrade u-boot to 2020.2 ?
Would you try to generate your project from scratch if you don't know how to upgrade ?
best regards,
o02
Thank you for your kind answer.
I am writing a question through Google Translator, so please understand even if it is strange.
I currently created a project in vivado 2020.2, and likewise PETALINUX is using version 2020.2.
Even if you go from scratch, it's okay if PETALINUX 2020.2 can boot.
If you can give any advice, please.
