rdb9879
petalinux: Enabling fpga_manager
I'm trying to follow some other forum threads (https://forums.xilinx.com/t5/Embedded-Linux/ZynqMP-PL-Programming-Throught-Linux-petalinux-2016-3/td-p/754914) on using the petalinux command line to reprogram the PL. It looks like a command would be similar to this:
"echo bitstream.bin > /sys/class/fpga_manager/fpga0/firmware"
However, I don't have "/fpga0/firmware" available in that directory. I do have "/sys/class/fpga_manager/" but it's an empty directory. I'm using petalinux 2017.4.
I'm assuming I need to enable that somewhere in "petalinux-config -c ..." but I am having trouble finding it.
Any help?
trigger
Hi @rdb9879,
For info i'm using a zynq7000 too and i don't have /sys/class/fpga_manager/fpga0/firmware
You shouldn't try to flash your bitstream with echo cmd.
Please try cat bitstream.bit > /dev/xdevcfg
Cheers,
Trigger
gudishak
You can check below configuration.
Device Drivers ---> FPGA Configuration Support ---> <*> Xilinx Zynqmp FPGA
Also refer below wiki
http://www.wiki.xilinx.com/Solution+ZynqMP+PL+Programming
Best Regards
Kranthi
rdb9879
I don't have the Xilinx Zynqmp FPGA option...
To get to this menu, I went "petalinux-config -c kernel"
rdb9879
Any more ideas on this?
trigger
Hi @rdb9879,
Which board do you use ? Custom ?
It's strange because this part of kernel is called by defconfig -> https://github.com/Xilinx/linux-xlnx/blob/master/arch/arm/configs/xilinx_zynq_defconfig#L217
Cheers,
Trigger
rdb9879
I'm using the Avnet Microzed. But when I created the petalinux project, I did not import a BSP, I just created a new project and imported the *.hdf file.
stephenm
Microzed is zynq7000, not zynqmp
rdb9879
Okay, then I guess I will circle back around to my original problem:
This command doesn't work:
because the sub directories "fpga0/firmware" do not exist. What do I do to make these directories exist? Ultimately, I am trying to reprogram the FPGA fabric with a new *.bit file using the command line.
trigger
Hi @rdb9879,
Cheers,
Trigger
