petalinux-boot failed
I'm trying to use "petalinux-boot --jtag --u-boot" to boot u-boot on my board. But failed. Anybody can help?
My board is an zynq ultrascale+ device.  Vivado 2017.4 is installed on ubuntu 16.04.  Ubuntu is installed by VMware Workstation.  The JTAG cable i'm using is Xilinx's Platform Cable USB II.  I'm not sure if the cable driver have been correctly installed. How to confirm this?
Re: petalinux-boot failed
@stephenm, Thank you!
I tried. XSCT can't detect "targets". I checked the cable. The cable connection is good because if i switch the connection from Ubuntu back to Windows, the Vivado in Windows can detect the cable.
Then, I tried to CD into the folder "/opt/Xilinx/Vivado/2017.4/data/xicom/cable_drivers/lin64/install_script/install_drivers "
Then, "./install_drivers".
After the installation, disconnect and reconnect the cable inside ubuntu, the XSCT can detect the "targets" now.
Can you connect to the board using XSCT:
connect
targets
Make sure you can see the chain here. If not, then the issue might be with the cable connetion on your ubuntu machine.
