dansenxu
petalinux-boot --jtag --u-boot failed on vmware ubuntu
I install ubuntu  on VMware workstation,
when i run petalinux-boot --jtag --u-boot
it always failed, but it is ok to download bit stream in vivado,
so i want to know how to solve this problem..
can anyone help me , thank you.
dansen@ubuntu:~/zcu102/zcu102/apu/petalinux_bsp$ petalinux-boot --jtag --u-boot -v
XSDB Script:
INFO: Launching XSDB for file download and boot.
connect
targets -set -nocase -filter {name =~ "*A53*#0"}
puts stderr "INFO: Downloading ELF file to the target."
dow "/home/dansen/zcu102/zcu102/apu/petalinux_bsp/images/linux/pmufw.elf"
after 2000
con
source /home/dansen/zcu102/zcu102/apu/petalinux_bsp/project-spec/hw-description/psu_init.tcl
dow "/home/dansen/zcu102/zcu102/apu/petalinux_bsp/images/linux/zynqmp_fsbl.elf"
after 2000
con
after 4000; stop; catch {stop}; psu_ps_pl_isolation_removal; psu_ps_pl_reset_config
dow "/home/dansen/zcu102/zcu102/apu/petalinux_bsp/images/linux/u-boot.elf"
after 2000
dow "/home/dansen/zcu102/zcu102/apu/petalinux_bsp/images/linux/bl31.elf"
after 2000
con
exit
INFO: This may take a few minutes, depending on the size of your image.
rlwrap: warning: your $TERM is 'xterm-256color' but rlwrap couldn't find it in the terminfo database. Expect some problems.: Inappropriate ioctl for device
attempting to launch hw_server
****** Xilinx hw_server v2017.1
**** Build date : Apr 14 2017-19:01:52
** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
Failed to download /home/dansen/zcu102/zcu102/apu/petalinux_bsp/images/linux/pmufw.elf
APU L2 cache is held in reset
invoked from within
"::tcf::eval -progress {
apply {{info} {
switch -- [lindex $info 0] {
"info" {
puts -nonewline "\r[lindex $info 1]"
"warning" {
puts "\n[lindex $info 1]"
"data" {
puts -nonewline "\r[lindex $info 1] of [lindex $info 2] complete"
"done" {
flush stdout
::xsdb::abort_check
}}} {::tcf::cache_enter tcfchan#0 {tcf_cache_eval {download_cache_client ::tcfclient#0::arg}}}"
(procedure "::tcf::cache_eval_with_progress" line 2)
invoked from within
"::tcf::cache_eval_with_progress $params(chan) [list download_cache_client $argvar] {
apply {{info} {
"info" ..."
(procedure "dow" line 67)
invoked from within
"dow "/home/dansen/zcu102/zcu102/apu/petalinux_bsp/images/linux/pmufw.elf""
(file "/tmp/tmp.3fg6Agefww" line 5)
shabbirk
Hi @dansenxu
Can you give a try on another board if you have ?
Best Regards
Shabbir
dansenxu
now i only have one zcu102 board.
it is ok to run the command on the other PC with ubuntu not install on VMware.
so i think the board is ok..
