Visitor mrzhang_
petalinux-boot --qemu --prebuilt 3 failed
When I run command
Tools :
PC : Ubuntu 2016.04
Petalinux 2017.2
Error:
INFO: Set QEMU tftp to /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux
用法: grep [选项]... PATTERN [FILE]...
试用'grep --help' 来获得更多信息。
INFO: TCP PORT is free
INFO: Starting aarch64 QEMU
INFO:  qemu-system-aarch64 -M arm-generic-fdt -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true   -display none -device loader,file=/home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/pre-built/linux/images/pmu_rom_qemu_sha3.elf,cpu-num=0 -gdb tcp::9000 -dtb /tmp/tmp.vAFrFPmxVo     -hw-dtb /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.0ey3keugwi -pflash /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/nand0.qcow2 -pflash /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/nand0.qcow2 -m 4G
qemu-system-aarch64: Unable to get size of device tree file '/tmp/tmp.vAFrFPmxVo'
qemu-system-aarch64: Error: Unable to load Device Tree /tmp/tmp.vAFrFPmxVo
INFO:  qemu-system-aarch64 -M arm-generic-fdt -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true   -display none -device loader,file=/home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/pre-built/linux/images/pmufw.elf,cpu-num=0 -gdb tcp::9000 -dtb /tmp/tmp.Vx8DsA3UUZ     -hw-dtb /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.0ey3keugwi -pflash /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/nand0.qcow2 -pflash /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/nand0.qcow2 -m 4G
qemu-system-aarch64: Unable to get size of device tree file '/tmp/tmp.Vx8DsA3UUZ'
qemu-system-aarch64: Error: Unable to load Device Tree /tmp/tmp.Vx8DsA3UUZ
INFO:  qemu-system-aarch64 -M arm-generic-fdt -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=true   -display none -device loader,file=/home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/pre-built/linux/images/bl31.elf,cpu-num=0 -device loader,file=/home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/pre-built/linux/images/Image,addr=0x00080000 -device loader,file=/home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/pre-built/linux/images/system.dtb,addr=0x1407f000 -device loader,file=/home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/build/misc/linux-boot/linux-boot.elf -gdb tcp::9000 -dtb /tmp/tmp.8w6EUmsvxa     -hw-dtb /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/zynqmp-qemu-multiarch-arm.dtb -machine-path /tmp/tmp.0ey3keugwi -pflash /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/nand0.qcow2 -pflash /home/ceshiyiqi/zcu102/xilinx-zcu102-2017.2/images/linux/nand0.qcow2 -m 4G
qemu-system-aarch64: Unable to get size of device tree file '/tmp/tmp.8w6EUmsvxa'
qemu-system-aarch64: Error: Unable to load Device Tree /tmp/tmp.8w6EUmsvxa
Re: petalinux-boot --qemu --prebuilt 3 failed
Seems to be a parsing issue here. Can you try call the command manually, and remove the highlighted option
