petalinux-build err
I install Petalinux2017.4,and create a project base the zcu102bsp,I build the project,and get a err
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:11
Checking sstate mirror object availability: 100% |###############| Time: 0:00:28
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
fsbl-2017.4+gitAUTOINC+77448ae629-r0 do_compile: NOTE: fsbl: compiling from external source tree /opt/pkg/petalinux/tools/hsm/data/embeddedsw
ERROR: fsbl-2017.4+gitAUTOINC+77448ae629-r0 do_compile: Function failed: do_compile (log file is located at /opt/pkg/project/ZCU102_PRJ/build/tmp/work/plnx_aarch64-xilinx-linux/fsbl/2017.4+gitAUTOINC+77448ae629-r0/temp/log.do_compile.5655)
ERROR: Logfile of failure stored in: /opt/pkg/project/ZCU102_PRJ/build/tmp/work/plnx_aarch64-xilinx-linux/fsbl/2017.4+gitAUTOINC+77448ae629-r0/temp/log.do_compile.5655
Log data follows:
| DEBUG: Executing python function xsct_externalsrc_compile_prefunc
| DEBUG: Python function xsct_externalsrc_compile_prefunc finished
| DEBUG: Executing shell function do_compile
| Starting xsdk. This could take few seconds... Picked up _JAVA_OPTIONS: -Duser.home=/opt/pkg/project/ZCU102_PRJ/build/tmp/xsctenv
| Eclipse:
| An error has occurred. See the log file
| /opt/pkg/project/ZCU102_PRJ/components/plnx_workspace/fsbl/.metadata/.log.
| XSCTHELPER INFO: Empty WorkSpace
| Eclipse:
| timeout while establishing a connection with SDK
| while executing
| "error "timeout while establishing a connection with SDK""
| (procedure "getsdkchan" line 111)
| invoked from within
| "getsdkchan"
| (procedure "projects" line 35)
| invoked from within
| "projects -clean -type $type -name $name"
| (procedure "clean_n_build" line 2)
| invoked from within
| "clean_n_build bsp $params(bspname)"
| invoked from within
| "if { $params(ws) ne "" } {
| #Local Work Space available
| setws $params(ws)
| if { [catch {importprojects $params(ws)} result] } {
| puts "XSCTHELPER IN..."
| (file "/opt/pkg/project/ZCU102_PRJ/build/tmp/work/plnx_aarch64-xilinx-linux/fsbl/2017.4+gitAUTOINC+77448ae629-r0/app.tcl" line 120)
| WARNING: /opt/pkg/project/ZCU102_PRJ/build/tmp/work/plnx_aarch64-xilinx-linux/fsbl/2017.4+gitAUTOINC+77448ae629-r0/temp/run.do_compile.5655:1 exit 1 from 'xsct /opt/pkg/project/ZCU102_PRJ/build/tmp/work/plnx_aarch64-xilinx-linux/fsbl/2017.4+gitAUTOINC+77448ae629-r0/app.tcl -ws /opt/pkg/project/ZCU102_PRJ/build/../components/plnx_workspace/fsbl -pname fsbl -rp /opt/pkg/petalinux/tools/hsm/data/embeddedsw -do_compile 1'
| ERROR: Function failed: do_compile (log file is located at /opt/pkg/project/ZCU102_PRJ/build/tmp/work/plnx_aarch64-xilinx-linux/fsbl/2017.4+gitAUTOINC+77448ae629-r0/temp/log.do_compile.5655)
ERROR: Task (/opt/pkg/petalinux/components/yocto/source/aarch64/layers/meta-xilinx-tools/recipes-bsp/fsbl/fsbl_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2406 tasks of which 1873 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build project
So,i donot know why?
Observer trilok_4
Re: petalinux-build err
I also faced same problem. Then I disabled First Stage Bootloader in Linux Components selection, now build was success.
And I noticed one thing, if create BOOT.bin using petalinux command "petalinux-package --boot --fsbl <FSBL image> --fpga <FPGA bitstream> --u-boot" and place the image on target only FPGA will program but U-boot won't boot I don't know why?. So I taken U-boot elf from image folder in Petalinux project and created BOOT.bin(FSBL.elf+u-boot.elf) using Xilinx SDK. Using this BOOT.bin u-boot is booting on board.
Please help me out to get rid of from the issue.
Board : Digilent Zybo
See if this answer record helps you:-
https://www.xilinx.com/support/answers/69812.html
Best Regards
Shabbir
Please post the content of the file /opt/pkg/project/ZCU102_PRJ/components/plnx_workspace/fsbl/.metadata/.log
That will help us to find the issue.
Chaitanya
The XSDK is timing out. Are you on a Virtual Machine? How many processors have you got?
I recommend just building the FSBL separately
petalinux-build -c bootloader
Hi, @jingshuizhuxin, I'm facing the same problem.
Is it possible to share how did you fix this issue?
