petalinux-build error: Building Linux - linux kernel: No such file or directory
I'm runnung Ubuntu Linux 14.04 LTS.
I have followed the instructions for installing Petalinux and getting started manual. I have downloaded a example BSP and created a new project from that.
When I try to execute petalinux-build I got the failure:
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[ERROR] make: *** linux-kernel: No such file or directory.  Stop.
ERROR: Failed to build linux
Do I missing something from the tool-chain?
Re: petalinux-build error: Building Linux - linux kernel: No such file or directory
Problem solved.
Ubuntu uses dash as standard shell. Petalinux supports bash!
You can check by
ls -l /bin/sh
and change this by:
sudo dpkg-reconfigure dash
-> select no
Have a look at:
http://svenand.blogdrive.com/archive/165.html#.VGXPZW-GezA
Participant maximilianpohl
do you installed these libraries?
lib32gomp1
lib32ncursesw5
Yes, both libraries, lib32gomp1 and lib32ncursesw5 are installed.
However I could not install ia32-libs on my Ubuntu 64Bit System.
Problem solved.
You can check by
ls -l /bin/sh
and change this by:
-> select no
Have a look at:
