mark_sundance
petalinux-build error: Exception: BIT file package is not supported: 7z015clg485
Thanks your information. The problem is solved! However, then I was going to generate the BOOT.BIN image and it told not supporting the Z-0715 of the bitstream file.
petalinux-package --boot --fsbl images/linux/zynq_fsbl.elf --fpga subsystems/linux/hw-description/Zynq_subsystem_wrapper.bit --uboot
INFO: Generating zynq binary package BOOT.BIN...
FATAL: Exception: BIT file package is not supported: 7z015clg485
ERROR: Fail to create BOOT image
I've tried to find the solution here:
http://www.xilinx.com/support/answers/60430.html
replacing the patch with my "bootgen" files of SDK 2014.4 and petalinux2014.4, but it does not work either.
Do you have the patch for the right version? or any other proper solution?
achutha
@mark_sundance
Tha PATCH in the AR#60430 is for SDK 2014.1/2014.2 bootgen and it is fixed in 2014.3 version.
 I will verfiy with Petalinux at my end and will let you know on my findings.
Achutha
