petalinux-build error in the petalinux2019.1
In the petalinux2019.1, errors are reported when running petalinux-build to the location in the graph. Why?petalinux-build.png
Re: petalinux-build error in the petalinux2019.1
Can you proivde the test steps for reproducing ,so that will check and get back to you.
