yfycsy
petalinux build error.
I am trying to use petalinux tools 19.02 with my ubuntu 16.04. I created a petalinux project then try to build it.
But I got error. I checked every pre-requests for petalinux tool. Everything seems true. I couldnt understand problem. Can you help me fastly? Thank you for interest.
My error message when I enter to petalinux-build command in project directory.
furkan@furkan-X555LJ:/media/furkan/Data/PetalinuxProjects/xilinx-zcu104-2019.2$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
[INFO] generating user layers
[INFO] generating workspace directory
INFO: bitbake petalinux-user-image
Loading cache: 100% |#############################################################################################################| Time: 0:00:01
Loaded 3979 entries from dependency cache.
Parsing recipes: 100% |###########################################################################################################| Time: 0:00:05
Parsing of 2893 .bb files complete (2891 cached, 2 parsed). 3980 targets, 154 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |########################################################################################################| Time: 0:00:37
Checking sstate mirror object availability: 100% |################################################################################| Time: 0:00:50
Sstate summary: Wanted 342 Found 21 Missed 642 Current 1840 (6% match, 85% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: pmu-firmware-2019.2+gitAUTOINC+e8db5fb118-r0 do_populate_sysroot: Fatal errors occurred in subprocesses:
Command '['aarch64-xilinx-linux-strip', '--remove-section=.comment', '--remove-section=.note', '/media/furkan/Data/PetalinuxProjects/xilinx-zcu104-2019.2/build/tmp/work/zcu104_zynqmp-xilinx-linux/pmu-firmware/2019.2+gitAUTOINC+e8db5fb118-r0/sysroot-destdir/boot/pmu-firmware.elf']' returned non-zero exit status 1: Traceback (most recent call last):
File "/opt/pkg/petalinux/2019.2/components/yocto/source/aarch64/layers/core/meta/lib/oe/utils.py", line 272, in run
ret = self._target(*self._args, **self._kwargs)
File "/opt/pkg/petalinux/2019.2/components/yocto/source/aarch64/layers/core/meta/lib/oe/package.py", line 44, in runstrip
output = subprocess.check_output(stripcmd, stderr=subprocess.STDOUT)
File "/opt/pkg/petalinux/2019.2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.5/subprocess.py", line 316, in check_output
**kwargs).stdout
File "/opt/pkg/petalinux/2019.2/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.5/subprocess.py", line 398, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command '['aarch64-xilinx-linux-strip', '--remove-section=.comment', '--remove-section=.note', '/media/furkan/Data/PetalinuxProjects/xilinx-zcu104-2019.2/build/tmp/work/zcu104_zynqmp-xilinx-linux/pmu-firmware/2019.2+gitAUTOINC+e8db5fb118-r0/sysroot-destdir/boot/pmu-firmware.elf']' returned non-zero exit status 1
ERROR: pmu-firmware-2019.2+gitAUTOINC+e8db5fb118-r0 do_populate_sysroot: Function failed: sysroot_strip
ERROR: Logfile of failure stored in: /media/furkan/Data/PetalinuxProjects/xilinx-zcu104-2019.2/build/tmp/work/zcu104_zynqmp-xilinx-linux/pmu-firmware/2019.2+gitAUTOINC+e8db5fb118-r0/temp/log.do_populate_sysroot.4282
ERROR: Task (/opt/pkg/petalinux/2019.2/components/yocto/source/aarch64/layers/meta-xilinx-tools/recipes-bsp/pmu-firmware/pmu-firmware_git.bb:do_populate_sysroot) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6711 tasks of which 6698 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
chaoz
@yfycsy
Could you please attache " /media/furkan/Data/PetalinuxProjects/xilinx-zcu104-2019.2/build/tmp/work/zcu104_zynqmp-xilinx-linux/pmu-firmware/2019.2+gitAUTOINC+e8db5fb118-r0/temp/log.do_populate_sysroot.4282" for more details?
Chao
如果帖子有帮助,别忘“接受为解决方案”或“奖励”。谢谢!
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
yfycsy
Here file which you said
But I couldnat attach becaufe of extension format of file, so I changed the file name.
stephenm
can you run petalinux-build -c pmu-firmware
yfycsy
output of petalinux-build -c pmu-firmware
[INFO] building pmu-firmware
INFO: bitbake pmu-firmware
Loading cache: 100% |############################################| Time: 0:00:01
Parsing recipes: 100% |##########################################| Time: 0:00:06
Initialising tasks: 100% |#######################################| Time: 0:00:03
Checking sstate mirror object availability: 100% |###############| Time: 0:00:02
Sstate summary: Wanted 10 Found 1 Missed 18 Current 138 (10% match, 93% complete)
**kwargs).stdout
ERROR: Logfile of failure stored in: /media/furkan/Data/PetalinuxProjects/xilinx-zcu104-2019.2/build/tmp/work/zcu104_zynqmp-xilinx-linux/pmu-firmware/2019.2+gitAUTOINC+e8db5fb118-r0/temp/log.do_populate_sysroot.4467
NOTE: Tasks Summary: Attempted 622 tasks of which 621 didn't need to be rerun and 1 failed.
ERROR: Failed to build pmu-firmware
lucc2
Same problem here,
also on ubuntu 16.04
petalinux 2019.2
Great interest in finding a solution.
To reproduce error quicker than running full petalinux-build and try fixes in less time
petalinux-build -c pmu-firmware -x cleansstate
But the above is just to get/reproduce the error quicker.
Error Message I get, is same:====================
Command '['aarch64-xilinx-linux-strip', '--remove-section=.comment', '--remove-section=.note', '../projects/ultra96/peta/ultra96a/build/tmp/work/plnx_zynqmp-xilinx-linux/pmu-firmware/2019.2+gitAUTOINC+e8db5fb118-r0/sysroot-destdir/boot/pmu-firmware.elf']' returned non-zero exit status 1: Traceback (most recent call last):
File "../tools/xilinx/petlinux/components/yocto/source/aarch64/layers/core/meta/lib/oe/utils.py", line 272, in run
File "../tools/xilinx/petlinux/components/yocto/source/aarch64/layers/core/meta/lib/oe/package.py", line 44, in runstrip
File "../tools/xilinx/petlinux/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.5/subprocess.py", line 316, in check_output
**kwargs).stdout
File "../tools/xilinx/petlinux/components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.5/subprocess.py", line 398, in run
subprocess.CalledProcessError: Command '['aarch64-xilinx-linux-strip', '--remove-section=.comment', '--remove-section=.note', '../projects/ultra96/peta/ultra96a/build/tmp/work/plnx_zynqmp-xilinx-linux/pmu-firmware/2019.2+gitAUTOINC+e8db5fb118-r0/sysroot-destdir/boot/pmu-firmware.elf']' returned non-zero exit status 1
ERROR: Logfile of failure stored in: ../projects/ultra96/peta/ultra96a/build/tmp/work/plnx_zynqmp-xilinx-linux/pmu-firmware/2019.2+gitAUTOINC+e8db5fb118-r0/temp/log.do_populate_sysroot.21666
ERROR: Task (../tools/xilinx/petlinux/components/yocto/source/aarch64/layers/meta-xilinx-tools/recipes-bsp/pmu-firmware/pmu-firmware_git.bb:do_populate_sysroot) failed with exit code '1'
adefan
I have the same problem.
Any solution?
My take is that because Petalinux errors are basically random text, what would help is to share the configuration.
stephenm
is it just the pmufw? can you build the fsbl?
petalinux-build -c bootloader
The PMUFW and the FSBL are created in XSCT. I want to see if there is an issue here.
You could also just cd to the tmp directory (${TMPDIR}/ work/aarch64-xilinx-linux/pmufw) and call the make directly.
I sometimes had trouble with Petalinux and doing a clean or mrproper fixed it:
petalinux-build -x clean
petalinux-build -x mrproper
adefan
Thanks.  This is a good suggestion. My findings are :
The petalinux project was originally created on a different hard drive like /media/xxx/C48000xxxx/plnx_proj
After the petalinux project is created on the same hard drive as the system drive such as /home/ xxx/plnx_proj, the project builds successfully.
Ah, so I guess is the "tool pickiness". I think your finding is the solution.
duanev
I found that petalinux likes to source the user's .bashrc, making it highly sensitive to how ever you've customized your login account.  I fixed one of these yocto/source/aarch64/layers/core/meta/lib/oe/utils.py errors by short circuiting PL's attempt to use my .bashrc.  Try adding this to the top of your .bashrc:
env | grep PSEUDO_PASSWD 2>&1 > /dev/null && exit
 Here are a few other env vars PL seems to use in case PSEUDO_PASSWD doesn't work: PKG_CONFIG_SYSROOT_DIR, PSEUDO_DISABLED, READELF, or maybe just abort if PWD is equal to "/home/your_login/pl_proj_name/build".
