Observer yyt
petalinux-build errors!!!
petalinux 2017.3+vivado2017.3
编译官方下载的xilinx-zcu102-zu9-es2-rev1.0-v2017.3-final.bsp,能够生成BOOT.BIN
但是编译如下网址生成的bnn工程出错,bnn工程由make_hw.sh脚本生成。
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841949/Zynq+UltraScale+MPSoC+Accelerated+Image+Classification+via+Binary+Neural+Network+TechTip
log中主要错误提示如下:
ERROR: u-boot-xlnx-v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0 do_compile: oe_runmake failed
ERROR: u-boot-xlnx-v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0 do_compile: Function failed: do_compile (log file is located at /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/temp/log.do_compile.57654)
ERROR: Logfile of failure stored in: /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/temp/log.do_compile.57654
ERROR: Function failed: do_compile (log file is located at /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/temp/log.do_compile.57654)
Summary: 1 task failed:
/home/subos/mysoftware/petalinux2017.3/components/yocto/source/aarch64/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2017.01.bb:do_compile
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
完整log如下:
subos@subos-virtual-machine:~/mysoftware/petalinux_zcu102_local$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:01:02
Parsing of 2466 .bb files complete (0 cached, 2466 parsed). 3259 targets, 225 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:38
Checking sstate mirror object availability: 100% |###########################################################################################################################################| Time: 0:14:05
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
fsbl-2017.3+gitAUTOINC+3c9f0cfde9-r0 do_compile: NOTE: fsbl: compiling from external source tree /home/subos/mysoftware/petalinux2017.3/tools/hsm/data/embeddedsw
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 4 CROSS_COMPILE=aarch64-xilinx-linux- CC=aarch64-xilinx-linux-gcc --sysroot=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/plnx_aarch64 V=1 HOSTCC=gcc -isystem/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -L/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/usr/lib -L/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath-link,/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath-link,/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath,/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath,/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/lib -Wl,-O1 -C /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git O=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/build all EXT_DTB=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/deploy/images/plnx_aarch64/plnx_aarch64-system.dtb
| make: Entering directory '/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git'
| make -C /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/build KBUILD_src=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git \
| -f /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/Makefile all
| make[1]: Entering directory '/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/build'
| make -f /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/Makefile silentoldconfig
| make -f /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/scripts/Makefile.build obj=scripts/basic
| ln -fsn /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git source
| /bin/sh /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/scripts/mkmakefile \
| /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git . 2017 01
| rm -f .tmp_quiet_recordmcount
| GEN ./Makefile
| make -f /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/scripts/Makefile.build obj=scripts/kconfig silentoldconfig
| mkdir -p include/config include/generated
| scripts/kconfig/conf --silentoldconfig Kconfig
| make -f /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/scripts/Makefile.autoconf || \
| { rm -f include/config/auto.conf; false; }
| mkdir -p include/asm
| if [ -d /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/mach-zynq/include/mach ]; then \
| dest=arch/arm/mach-zynq/include/mach; \
| else \
| dest=arch/arm/include/asm/arch-zynq; \
| fi; \
| ln -fsn /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/$dest include/asm/arch
| set -e; : ' CHK include/config.h'; mkdir -p include/; (echo "/* Automatically generated - do not edit */"; for i in $(echo "" | sed 's/,/ /g'); do echo \#define CONFIG_$i | sed '/=/ {s/=/ /;q; } ; { s/$/ 1/; }'; done; echo \#define CONFIG_BOARDDIR board/xilinx/zynq; echo \#include \<config_defaults.h\>; echo \#include \<config_uncmd_spl.h\>; echo \#include \<configs/"platform-top".h\>; echo \#include \<asm/config.h\>; echo \#include \<config_fallbacks.h\>;) < /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/scripts/Makefile.autoconf > include/config.h.tmp; if [ -r include/config.h ] && cmp -s include/config.h include/config.h.tmp; then rm -f include/config.h.tmp; else : ' UPD include/config.h'; mv -f include/config.h.tmp include/config.h; fi
| aarch64-xilinx-linux-gcc --sysroot=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/plnx_aarch64 -E -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -O2 -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__KERNEL__ -D__UBOOT__ -D__ARM__ -fno-pic -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -pipe -Iinclude -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/include -include /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include/linux/kconfig.h -nostdinc -isystem /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux/../../lib/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/6.2.1/include -DDO_DEPS_ONLY -dM /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include/common.h > u-boot.cfg.tmp && { grep 'define CONFIG_' u-boot.cfg.tmp > u-boot.cfg; rm u-boot.cfg.tmp; } || { rm u-boot.cfg.tmp; false; }
| aarch64-xilinx-linux-gcc --sysroot=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/plnx_aarch64 -x c -DDO_DEPS_ONLY -M -MP -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -O2 -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__KERNEL__ -D__UBOOT__ -D__ARM__ -fno-pic -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -pipe -Iinclude -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/include -include /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include/linux/kconfig.h -nostdinc -isystem /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux/../../lib/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/6.2.1/include -MQ include/config/auto.conf /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include/common.h > include/autoconf.mk.dep || { rm include/autoconf.mk.dep; false; }
| sed -n -f /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/tools/scripts/define2mk.sed u-boot.cfg | while read line; do if [ -n "" ] || ! grep -q "${line%=*}=" include/config/auto.conf; then echo "$line"; fi done > include/autoconf.mk
| touch include/config/auto.conf
| set -e; : ' CHK include/config/uboot.release'; mkdir -p include/config/; echo "2017.01$(/bin/sh /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/scripts/setlocalversion /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git)" < include/config/auto.conf > include/config/uboot.release.tmp; if [ -r include/config/uboot.release ] && cmp -s include/config/uboot.release include/config/uboot.release.tmp; then rm -f include/config/uboot.release.tmp; else : ' UPD include/config/uboot.release'; mv -f include/config/uboot.release.tmp include/config/uboot.release; fi
| set -e; : ' CHK include/generated/timestamp_autogenerated.h'; mkdir -p include/generated/; (if test -n "${SOURCE_DATE_EPOCH}"; then SOURCE_DATE="@${SOURCE_DATE_EPOCH}"; DATE=""; for date in gdate date.gnu date; do ${date} -u -d "${SOURCE_DATE}" >/dev/null 2>&1 && DATE="${date}"; done; if test -n "${DATE}"; then LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_DATE "%b %d %C%y"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_TIME "%T"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_TZ "%z"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_DMI_DATE "%m/%d/%Y"'; else return 42; fi; else LC_ALL=C date +'#define U_BOOT_DATE "%b %d %C%y"'; LC_ALL=C date +'#define U_BOOT_TIME "%T"'; LC_ALL=C date +'#define U_BOOT_TZ "%z"'; LC_ALL=C date +'#define U_BOOT_DMI_DATE "%m/%d/%Y"'; fi) < /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/Makefile > include/generated/timestamp_autogenerated.h.tmp; if [ -r include/generated/timestamp_autogenerated.h ] && cmp -s include/generated/timestamp_autogenerated.h include/generated/timestamp_autogenerated.h.tmp; then rm -f include/generated/timestamp_autogenerated.h.tmp; else : ' UPD include/generated/timestamp_autogenerated.h'; mv -f include/generated/timestamp_autogenerated.h.tmp include/generated/timestamp_autogenerated.h; fi
| ERROR: oe_runmake failed
| GEN ./Makefile
| if [ -f /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/.config -o -d /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include/config ]; then \
| echo >&2 " /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git is not clean, please run 'make mrproper'"; \
| echo >&2 " in the '/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git' directory.";\
| /bin/false; \
| fi;
| set -e; : ' CHK include/generated/version_autogenerated.h'; mkdir -p include/generated/; (echo \#define PLAIN_VERSION \"2017.01\"; echo \#define U_BOOT_VERSION \"U-Boot \" PLAIN_VERSION; echo \#define CC_VERSION_STRING \"$(LC_ALL=C aarch64-xilinx-linux-gcc --sysroot=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/plnx_aarch64 --version | head -n 1)\"; echo \#define LD_VERSION_STRING \"$(LC_ALL=C aarch64-xilinx-linux-ld.bfd --version | head -n 1)\"; ) < include/config/uboot.release > include/generated/version_autogenerated.h.tmp; if [ -r include/generated/version_autogenerated.h ] && cmp -s include/generated/version_autogenerated.h include/generated/version_autogenerated.h.tmp; then rm -f include/generated/version_autogenerated.h.tmp; else : ' UPD include/generated/version_autogenerated.h'; mv -f include/generated/version_autogenerated.h.tmp include/generated/version_autogenerated.h; fi
| make -f /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/scripts/Makefile.build obj=.
| mkdir -p lib/
| aarch64-xilinx-linux-gcc --sysroot=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/plnx_aarch64 -Wp,-MD,lib/.asm-offsets.s.d -nostdinc -isystem /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux/../../lib/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/6.2.1/include -Iinclude -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/include -include /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include/linux/kconfig.h -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/. -I. -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -fno-pic -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -pipe -march=armv5 -D__LINUX_ARM_ARCH__=7 -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/mach-zynq/include -DDO_DEPS_ONLY -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(asm_offsets)" -D"KBUILD_MODNAME=KBUILD_STR(asm_offsets)" -fverbose-asm -S -o lib/asm-offsets.s /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/lib/asm-offsets.c
| mkdir -p arch/arm/lib/
| aarch64-xilinx-linux-gcc --sysroot=/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/plnx_aarch64 -Wp,-MD,arch/arm/lib/.asm-offsets.s.d -nostdinc -isystem /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/sysroots/x86_64-linux/usr/bin/aarch64-xilinx-linux/../../lib/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/6.2.1/include -Iinclude -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/include -include /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/include/linux/kconfig.h -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/. -I. -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -fno-pic -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -pipe -march=armv5 -D__LINUX_ARM_ARCH__=7 -I/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/mach-zynq/include -DDO_DEPS_ONLY -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(asm_offsets)" -D"KBUILD_MODNAME=KBUILD_STR(asm_offsets)" -fverbose-asm -S -o arch/arm/lib/asm-offsets.s /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/lib/asm-offsets.c
| /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/arch/arm/lib/asm-offsets.c:1:0: error: unknown value 'armv5' for -march
| /home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/lib/asm-offsets.c:1:0: error: unknown value 'armv5' for -march
| make[2]: *** [/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/./Kbuild:44: lib/asm-offsets.s] Error 1
| make[2]: *** Waiting for unfinished jobs....
| make[2]: *** [/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/./Kbuild:65: arch/arm/lib/asm-offsets.s] Error 1
| make[1]: *** [/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git/Makefile:1270: prepare0] Error 2
| make[1]: Leaving directory '/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/build'
| make: *** [Makefile:150: sub-make] Error 2
| make: Leaving directory '/home/subos/mysoftware/petalinux_zcu102_local/build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2017.01-xilinx-v2017.3+gitAUTOINC+da811c4511-r0/git'
ERROR: Task (/home/subos/mysoftware/petalinux2017.3/components/yocto/source/aarch64/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2017.01.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2382 tasks of which 1873 didn't need to be rerun and 1 failed.
Observer yyt
Re: petalinux-build errors!!!
petalinux-create  -t project  --template zynqMP  --name zcu102zynqMP
问题在于--template zynq,应该为 --template zynqMP
Looks like an error with the cross-compiler.
Observer yyt
Visitor chulifuu
I also encountered this problem. Can you solve it? If it is solved, can you tell me the solution?
Observer yyt
我当时的问题在于--template 的参数没写对,改为问题在于--template zynqMP就正常了,详细可参考ug1144、ug1157
