burleygreg
petalinux-build --sdk failed for zc702
I am able to create a petalinux project using the zc702 bsp, using petalinux 2020.2 on CentOS7.8, without changing any configuration options.  That is, this is the simplest project I can think of, so am a bit surprised at the result.
petalinux-build works fine, and completes successfully.
But, petalinux-build --sdk fails with the following error message:
ERROR: petalinux-image-minimal-1.0-r0 do_rootfs: The postinstall intercept hook 'update_gio_module_cache' failed
Does anyone have any suggestions? I would appreciate any hints or leads on how to solve this.
ashwinil
Hi @burleygreg ,
QEMU 5.0 required more mmap size to build, but default centOS or RHEL has lesser value , so need to update build machine configuration.
Please update build machine configuration as below and retry.
  1. vi /etc/sysctl.conf
  2. add mmap entry in the file : vm.mmap_min_addr = 65536
  3. save the file
  4. sysctl -p
This update requires sudo permission on machine.
Please let us know if your facing issue.
ashwinil
Hi @burleygreg ,
  3. save the file
  4. sysctl -p
burleygreg
Thank you so much this worked for me and solved the problem.
