Visitor potteit
petalinux-config -c rootfs error
My environment is ubuntu 16 and I installed all of the dependencies outlined to be installed in ug1144 petalinux tools reference guide. However, I am seeing the following error when I run petalinux-config -c rootfs. Does anyone know what the issue could be?
tpottei1@tpottei1-ThinkPad-E570:~/firstZedProj/firstProj$ petalinux-config -c rootfs
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] configuring: rootfs
[INFO] generating kconfig for Rootfs
[INFO] menuconfig rootfs
ERROR: Failed to menu config rootfs component
ERROR: Failed to config rootfs.
tpottei1@tpottei1-ThinkPad-E570:~/firstZedProj/firstProj$ cd project-spec/
Observer pauldward
Re: petalinux-config -c rootfs error
Check the file <proj_dir>/build/config.log and it should tell you the error. I had this problem and the shell where I ran petalinux-config needed to be resized to be larger.
