petalinux-config --get-hw-description failing 2017.4
I'm attempting to reconfigure the PetaLinux BSP.
I ran the following command:
petalinux-config --get-hw-description=~/zwilcox/mpsoc_workspace/chapter1/edt_zcu102/edt_zcu102.sdk/
INFO: Rename edt_zcu102_wrapper.hdf to system.hdf
[INFO] generating Kconfig for project
ERROR: Failed to generate /home/zwilcox/petalinux/xilinx-zc702-2017.4/build/misc/config/Kconfig.syshw
ERROR: Failed to Kconfig project
ERROR: Failed to generate System hardware Kconfig file.
I've tried to change the tools/hsm/bin/xsct line 137
"$RDI_BINROOT"/unwrapped/"$RDI_PLATFORM$RDI_OPT_EXT"/rlwrap -rc -f "$RDI_APPROOT"/scripts/xsdb/xsdb/cmdlist -H "$HOME"/.xsctcmdhistory "$RDI_BINROOT"/loader -exec rdi_xsct "${RDI_ARGS[@]}"
To:
#"$RDI_BINROOT"/unwrapped/"$RDI_PLATFORM$RDI_OPT_EXT"/rlwrap -rc -f "$RDI_APPROOT"/scripts/xsdb/xsdb/cmdlist -H "$HOME"/.xsctcmdhistory "$RDI_BINROOT"/loader -exec rdi_xsct "${RDI_ARGS[@]}"
As indicated by this post:
https://forums.xilinx.com/t5/Embedded-Linux/petalinux-config-get-hw-description-failing-2017-4/m-p/826916
However, I'm still getting the same error.
Re: petalinux-config --get-hw-description failing 2017.4
I reinstalled the petalinux. Recreated the project with the bsp.
Now it works. Thanks for all who helped :)
I had similar errors after updating an existing project in vivado and smt was going wrong when exporting.
Did you try to go through complete vivado pipeline (synthesis, implement,...) again, including rebuilding the wrapper? Then export again for sdk and try again.
It solved get-hw description errors several times for me
I rebuilt the wrapper and exported for the SDK again. I have no HDL so didn't synthesize.
ran the following:
"petalinux-config --get-hw-description=~/path/to/hdf/file/"
And still getting:
INFO: Getting hardware description...
webtalk failed:PetaLinux statistics:extra lines detected:notsent_nofile!
webtalk failed:Failed to get PetaLinux usage statistics!
