maryiaco
petalinux-config xrealloc: ../bash/subst.c:5184: cannot allocate
Good morning,
I'm working with a workstation with OS Debian Wheezy and I use Petalinux 2014.2.
I'm trying to configure my lib with the command "petalinux-config -c rootfs". The command is run properly until string  "*** End of configuration", but after there is a list of such strings:
petalinux-linuxsys-utils: xrealloc: ../bash/subst.c:5184: cannot allocate 268435456 bytes (537595904 bytes allocated).
I tried to start the PC without graphical environment, but the execution of the command ends with the same cause of failure.
My PC has 2GB of RAM and 250GB of HDD(that was used only on 6%).
What is success?  Do you have any advice for me to solve this problem?
Thank you very much!!!!!
