Observer randriantsoa
petalinux-config
I tried to reconfigurate my petalinux project but I got the following errors:
(base) alexandre@alexandre-Latitude-5490:/home/Vivado/2019.1/Exemple2/xilinx-zcu102-2019.1$ petalinux-config --get-hw-description=/home/Vivado/2019.1/Exemple2/xilinx-zcu102-2019.1/hardware/xilinx-zcu102-2019.1/xilinx-zcu102-2019.1.sdk
INFO: Getting hardware description...
INFO: Rename edt_zcu102_wrapper.hdf to system.hdf
[INFO] generating Kconfig for project
[INFO] menuconfig project
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
ERROR: Failed to generate meta-plnx-generated layer
ERROR: Failed to config project.
ERROR: Get hw description Failed!.
Could you help me please?
Best regards
Re: petalinux-config
Then you might have some misconfiguraitons on one of your machines ;)
Please note the system requirements in UG1144 and the needed tools. There might also be unsupported versions from Ubuntu18.0x and 2019.Y or else.
Hi @randriantsoa
Can you please share the HDF, let me try to recreate the same and debug further?
Hi, I tried to send you the hdf but I get the attached post error message.
Could you tell me why Xilinx forum didn't accept my hdf as attached file?
Best regards,
@randriantsoa  You can upload the hdf it with a .zip extension. You can view it with WinRar / 7zip / whatever. Simply rename it.
Silly that Xilinx doesn't allow their own file formats for upload...
I  executed  the same configuration command with another PC by using the same hdf. It worked.
So the problem didn't come from the hdf. It could come from either petalinux or the PC.
For the case where it didn't work, I used i5 7300U CPU, RAM 8 Go,
About free disk space, df command gives :
Filesystem 1K-blocks Used Available Use% Mounted on
udev 3982820 0 3982820 0% /dev
tmpfs 802600 9688 792912 2% /run
/dev/sda5 49328432 21712048 25087472 47% /
tmpfs 4012988 252 4012736 1% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 4012988 0 4012988 0% /sys/fs/cgroup
/dev/sda2 97280 30626 66654 32% /boot/efi
/dev/sda6 151991436 87755964 56491632 61% /home
tmpfs 802600 4 802596 1% /run/user/108
tmpfs 802600 76 802524 1% /run/user/1000
Do you have an idea?
Best regards,
I use ubuntu 16.04.
I will re-install petalinux.
Bst regards,
Hi,I have met the same misconfiguration, have you correted the mistakes and sucesessfully reconfiged your HDF in your former PC?
Best regards
